Go to Post Instead of "Team XXXX graciously accepts" how about just a big "yeaaaahhhhh!" ? - sanddrag [more]
Unread 11-02-2005, 17:14
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
pic: Steering mechanism
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 11-02-2005, 17:15
Re: pic: Steering mechanism
The steering is very interesting, but what I'm even more curious about is how did you adapt to the strange gear on the jideco motor?
Unread 11-02-2005, 19:03
Pretty cool. Most teams use tank steering. How did you decide to use "automobile" steering instead?
Unread 11-02-2005, 23:10
CRAZYMADI CRAZYMADI is offline
CRAZYMADI can only hope to improve
The gear is biult to give more revolution per mintue to our four-wheel steerign drive. Keeping in mind that there will be six robots on the field at the same time, Robots must move on sharp angles and possibly on faster pase. Our steering system fulfil the requirements and is pretty light. So far with the gear boxes, four wheel steering system and arm, we are still under 115 lbs.
Unread 11-02-2005, 23:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Nice. Typically you only see tank or "skid" stearing, or a form of omni-drive. Occasionally a robot who can "crab drive" or strafe too(especially in stack attack). But very rarely akerman(sp?) steering.
Unread 11-02-2005, 23:19
Team's that I remember having it are Crescenta Valley 589 in 2003 and Archer (#?) in 2004.
Unread 11-02-2005, 23:42
Greg Perkins's Avatar
7 years, allready!!???!?!?!
AKA: Mongo
this kinda looks like what 121 did in 2001.
except they made their robot turn in the middle via a vandoor motor. basically 4 wd with tthe robot looking like this...>o<... with the <'s being the wheels and chassis, and the o is the pivot...
it was pretty amazing
i like this approach to driving, most drivers allready own a car (or drive one) so any time a car steering system comes up its second nature.
Unread 13-02-2005, 11:40
None #0612
Yes, this type of steering mechanism is referred to as Ackerman steering. Each wheel turns around its own turning axle, in our case both the front and rear wheels turn, so we get a very small steering radius.
Due to the sharp turning angle we have (45 degrees), the fact that we turn all 4 wheels, and the extreme grip of our tires on carpet (coefficient of friction is about 1.2!), we cannot tolerate any slip angle (difference between the angle the wheel is actually turned to and the angle it should be turned to to remain tangent to the turning circle), so we had to make the inside and outside wheels turn different amounts, so they remain tangent to the circumference of the turning circle they are supposed to follow.
It makes for some interesting mechanical design, as well as some neat programming.
Here is a photo of the steering shafts (note that we also have 4 wheel drive in addition to 4 wheel steering):
The steering arms of the left wheels are connected together, so their steering angle is identical. The same is done on the right wheels. The left and right sides are driven by independent steering motors, each with its own steering angle sensor. When the driver pushes the joystick to the left, say 20°, the left wheels become the inside wheels, and the left steering motor turns the wheels to the desired 20° steering angle, as measured by a potentiometer connected to the steering axle.
So, referring to the diagram below, we can calculate θo as follows:
tanθi = W/Xi
So Xi = W/Tanθi
Tanθo = W/(Xi+T)
θo = ArcTan(W/(Xi+T)
= ArcTan(W/(W/Tanθi +T)
We are also using an electronic differential, by setting the relative speed of the inside and outside motors to be proportional to their respective turn radii.
We also plan to add speed-sensitive steering, so at high speed the ratio between joystick angle and turn angle is reduced. Hopefully that will minimize the chance of flipping over with our 100" arm extended.
Unread 13-02-2005, 12:02
Mirza95vx Mirza95vx is offline
The BOSNIAN
AKA: Mirza Strujo
None #1511 (Rolling Thunder)
Mirza95vx is a jewel in the roughMirza95vx is a jewel in the roughMirza95vx is a jewel in the roughMirza95vx is a jewel in the rough
Send a message via AIM to Mirza95vx
pretty sweet. Very diffrent and original
Rolling Thunder 1511 Beware of the THUNDER
2005 Rookie All-Star Award-- FLRC,
Quarter Finalists-- FLRC,
Semi Finalists-- Buckeye,
Highest Rookie Seed-- Buckeye,
Team Spirit-- GTR,
Rookie Inspiration-- GTR,
Highest International Score 128-0--GTR
Greater Toronto Regional Winners-- Thanks to 1114 and 1305
Congratulations to Kim Otoole for winning the M&M Excellence Award
SO FAR SO GOOD
27-12-2 FLRC & Buckeye & GTR
Rolling Thunder
Unread 13-02-2005, 13:24
None #0612
Re: pic: Steering mechanism - Jideco gear adapter
We CNC machined an adapter out of delrin. Email me if you want the G-code. We also did one for the Denso window motor, as the one FIRST provides is a bit bulky.
Unread 13-02-2005, 14:19
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Whoa, that is insanely cool...But will it last all of the competitions?
Unread 13-02-2005, 14:23
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
one word to describe it: wow ... thats incredible.. that must be one heck of a program to determine everything that fast.. hope yall will be at VCU, can't wait to see it!
Unread 13-02-2005, 15:05
None #0612
Yes, we will be at VCU, also in Atlanta.
Unread 13-02-2005, 15:36
Fixen Fixen is offline
The Sleepless Coder
FRC #0423 (Mechanical Mayhem)
Fixen is on a distinguished road
This is just downright awesome. Akkerman steering is something I didn't expect in this competition.
If you guys don't win the regionals, you'd at least awe the people.
Unread 13-02-2005, 19:05
psquared psquared is offline
psquared is an unknown quantity at this point
very nice design, that whole programming team must be really amazing
FIRST Mechanism Library Karthik General Forum 10 27-06-2005 23:33
pic: Shifting Mechanism 222 team222badbrad Robot Showcase 10 05-01-2005 18:01
Drill motor gearbox lock mechanism golf_cart_john Motors 2 28-04-2004 02:22
pic: Team 60 Mechanism CD47-Bot Robot Showcase 2 11-02-2004 21:47
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
