Go to Post I'm definitely not advocating PVC tanks. I'm just saying that if you're going to be an idiot, please be slightly less of an idiot. - FourPenguins [more]
Unread 13-02-2005, 23:37
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
pic: FP Cooler
-Rod-
Team 662
Colorado Springs, CO
Unread 13-02-2005, 23:38
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: FP Cooler
Do you have two fans running in reverse to suck air out?
Team 1257
Unread 13-02-2005, 23:42
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: pic: FP Cooler
The fans all blow in and force air through the motor via the input slots on the front of the motor.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Re: pic: FP Cooler
The words I would use to describe my first impression of this cannot be posted on these fine boards. NICE JOB!
Unread 13-02-2005, 23:43
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: pic: FP Cooler
Wow. If that motor overheats then you will know something is seriously wrong...
Unread 14-02-2005, 00:01
Tytus Gerrish's Avatar
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Re: pic: FP Cooler
well, it's deffenetly better than nothing
Unread 14-02-2005, 00:03
Re: pic: FP Cooler
I thought 4 fans were overkill, but once we decided upon a design for a shroud, it had 4 sides that were just the right size for a fan. Can you imagine the grief we mentors would get if the motor overheated because of a full current stall, and there were only three fans because I talked the students of the four one. The student that designed this was already talking about adding the second shroud in a pull configuration, but that would requre 5 additional fans and we do not have the clearance for it.
Unread 14-02-2005, 04:47
Engineering Mentor
FRC #0254
Re: pic: FP Cooler
Great Idea. You might see a nice little rendition of that on our robot sometime soon.
-Travis Covington
Unread 14-02-2005, 10:48
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: pic: FP Cooler
wouldnt one sucking and one pushing allow more airflow?
Unread 14-02-2005, 15:04
Re: pic: FP Cooler
If we were only trying to cool the outside then that might be a good idea, however we made some mods to the gear box to allow the air to get to the air intake holes on the motor. This allows the air to flow through motor and cool down the inside as well.
Unread 14-02-2005, 16:26
Evan Austin Evan Austin is offline
out of my mind, be back later
Evan Austin is an unknown quantity at this point
Re: pic: FP Cooler
We used a setup very similar to that 2 years ago except we made them out of plastic and they only used 1 fan to pull air through the motor. We didn't use fisher price last year, but we are again this year so I made another set very similar to them out of plastic on Saturday afternoon. These aluminum ones really look nice! However, now after seeing the motors tested on the robot Saturday, I am more worried about blowing up the plastic transmissions than I am of burning the motors
Unread 14-02-2005, 19:38
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
Re: pic: FP Cooler
If you are going to go through the trouble of rigging all that up, i would strongly reccomend not using those fans. They hardly move any air at all. You can get fans of the same size that move probably up to ten times more air.
1139 Alumni
pic: 45 teaser pic 2 Kyle Love Robot Showcase 7 02-02-2005 23:22
pic: Panoramic Pic from Nationals 2001 CD47-Bot Extra Discussion 19 23-03-2004 23:38
pic: Team PIC of 354 Westinghouse HS CD47-Bot Robot Showcase 4 29-02-2004 12:15
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
