Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 14-02-2005, 23:20
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
Re: pic: Ground Clearance (or the lack thereof)
Don't worry, you're correct.
Originally Posted by Section 3.2.1 of the Manual
Two colored Loading Zones are located in each quadrant of the Playing Field. The Loading Zone is colored red or blue, to correspond with the alliance located at the respective end of the field. The zone is in the shape of an equilateral triangle of three feet per edge, constructed of 1/4” HDPE, and attached to the carpet with Velcro. The zones in each quadrant are located immediately adjacent to the gate opening in the Guardrail System of that quadrant.
HDPE stands for High Density PolyEthylene
Teasers... or lack thereof Rickertsen2 Robot Showcase 29 30-01-2004 12:42
