Go to Post I am a FIRST addict. But I'm also sensible. - Rion Atkinson [more]
Unread 15-02-2005, 11:03
Gary Dillard's Avatar Unsung FIRST Hero
Gary Dillard Gary Dillard is offline
Generator of Entropy
AKA: you know, the old bald guy
FRC #2973 (The Mad Rockers)
Gary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond reputeGary Dillard has a reputation beyond repute
Send a message via AIM to Gary Dillard
Re: pic: (447) Is this legal?
Originally Posted by Steve W
There is no rule against heating the tubing, just modifying. It is still tube and it still has the same properties. If you heat it too much it will shrink and give less air flow, so be carefull.
I'd be REALLY careful about this. "It still has the same properties" could be argued against strongly from a safety standpoint, for 2 reasons I can think of:
1) If it remained coiled after you heated it, it permanently yielded. How do you know the plastically deformed material has the same properties (tensile/rupture strength, yield strength, elongation) that it had when it was qualified/certified to its pressure rating? If it hardened locally after heating the material may not redistribute stresses the same way.
2) How do you know that the thickness remained the same after heating? If it shrinks and gives less air flow, it could just as easily expand under load and cause both thinning and a larger diameter. Diameter and thickness are the primary variables in hoop strength - how do you know it's still qualified/certified to its pressure rating?
I think you're pushing this one a little too much Steve. My $.02
Close enough to taste it, too far to reach it
pic: (447) Innovation Break rufu5 Robot Showcase 15 19-02-2005 22:57
pic: (447) Our CMU CAM BOX rufu5 Extra Discussion 2 17-01-2005 19:10
pic: 33 / 447 CD47-Bot Extra Discussion 1 11-07-2004 14:31
pic: Sleepy 447 CD47-Bot Chit-Chat 4 23-05-2004 21:31
pic: Is this currently legal or considered exotic? CD47-Bot Robot Showcase 10 13-05-2003 01:09
