#11
Re: pic: Ground Clearance (or the lack thereof)
You should probably also consider the fact that this would make you very easy to high center. If one end of your robot ends up more than half an inch or so off the ground, you'd probably be left with all 4 wheels in the air and little recourse.
| Teasers... or lack thereof | Rickertsen2 | Robot Showcase | 29 | 30-01-2004 12:42 |
