Go to Post Is it bad when are you just sitting at home wishing KICKOFF was here. - JulieB [more]
Unread 15-02-2005, 17:02
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: pic: Ground Clearance (or the lack thereof)
"Traction devices may not have surface features such as metal, sandpaper, or hard plastic studs, cleats, or other attachments. Anchors, i.e. devices that are deployed/used to keep one’s robot in one place and prevent if from being moved by another robot, cannot use metal in contact with the carpet or other playing surfaces to 'stay put.'"
i dont know if the robot base rubbing on the ground counts under this , but you want to be careful.
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Teasers... or lack thereof Rickertsen2 Robot Showcase 29 30-01-2004 12:42
