Go to Post gears won't care if theyre running underwater... the electronics will ;) - Cory [more]
Unread 16-02-2005, 01:38
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Re: pic: 1072 from the top
Originally Posted by jgannon
Better get that drill going.
In all seriousness, do you really need two Fisher-Price motors on that winch? I can't imagine that you'd need that much power, and removing one would be a lot easier than putting several thousand holes into your bot.
Most likely we will need it to overcome the binding from all the cantilevering we're doing. It's also a lot easier to make cheeseholes then to design a mount for the spool without a second motor. The red plate on the bottom is 1/8th inch Al. I'm thinkin we can probably get a good chunk of weight out of that. Plus we're going to cut out a cross bar on the chassis that is redundent.
Alex
President
Team 1072 Harker Robotics
Time to the top... Joe Johnson Robot Showcase 60 14-04-2003 20:23
pic: Team #910 Top View CD47-Bot Extra Discussion 7 06-03-2003 12:41
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
One Robot Sitting on top of another question rkyro22 Rules/Strategy 14 09-01-2003 03:48
