pic: Crunch Time
Re: pic: Crunch Time
SAFETY GLASSES!!
Whats the box next to the RC? the one with 5 switches and the knob on it? motor controller? Looks pretty intresting, i like the blue!
http://www.chiefdelphi.com/forums/sh...&highlight=195 Eric |
Ah ok! Great idea, our team is doing something similar, but not nearly that complex! looks good!
looks good, and i like the chassis. It looks like it can do some intresting stuff.
Is that the cmu cam right next to the compressor? that seems like a pretty interesting place to mount it if it is....
Just an FYI to everyone as this is the first time ive seen it come up this year, there are certain color codes you need to follow when wiring your robot. Team 195 as pictured has done so, nice job!
5.3.9 Wiring Rules <R72> All wires distributing power with a constant polarity (i.e., except for Relay Module, Speed Controller, or sensor outputs) must be color-coded as follows: • Use Red, White, or Brown wire for +12 Vdc and +5 Vdc connections. • Use Black or Blue wire for Common (-) connections. |
#10
its blue....why?
#11
Just a word to the wise, Duct Tape is sometimes conductive, there is no way to tell but measure.
#12
They paint a plywood base, and their main team color is blue. |
#14
As to the questions pertaining to the project box mounted next to the compressor.. that would be the gyro. the CMU cam will be mounted sometime in the near future as right now, the cam is being put through its paces with the programmers. There should be a pic coming up tonight sometime with the work that was done today/tonight.
#15
| pic: Time machine platform | Koko Ed | Extra Discussion | 4 | 13-01-2005 23:18 |
| pic: The end of nationals...everyone left at the same time | CD47-Bot | Extra Discussion | 15 | 21-11-2004 18:50 |
| How long should production time be??? | archiver | 1999 | 4 | 23-06-2002 23:16 |
| more time before forums are marked as read | mike o'leary | CD Forum Support | 3 | 29-07-2001 05:34 |
| need help with time zone! | Ken Leung | General Forum | 6 | 25-06-2001 12:44 |
