Go to Post if you need a hammer you use a hammer and not an oscilloscope. - Andrew Schreiber [more]
Unread 16-02-2005, 16:18
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: pic: 97 revealed ( - end effector + cup of water )
Originally Posted by capenga
WOW!
so now you have a waiter bot, huh? I allways wanted one for me
Serious:
Have you programmed it by yourselves??
Is it overweight? Guess you'll need some speed holes...
LOL, It still needs a lot of tuning if it's going to wait tables. It oscillates quite a bit as is, especially going downward when gravity makes the arm go faster than it wants to. We're probably going to have to split the code into two cases: one for up and one for down.
I got a lot of help from members of the CD forum, particularly Chris Hibbner and Mike Betts. Their tips helped me figure out why the original code was acting strangely and make it much better. Check this thread: http://www.chiefdelphi.com/forums/sh...ad.php?t=34673.
As far was we can tell, we are about 15-20 lbs. under without our end-effector, which shouldn't weigh more than 5 lbs, so we shouldn't need any speed holes.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
pic: Team 968's robot revealed! CD47-Bot Robot Showcase 7 26-02-2004 19:37
pic: 2004 Game Revealed! CD47-Bot Extra Discussion 28 12-09-2003 12:08
pic: Dean's new water dispenser CD47-Bot Extra Discussion 30 27-08-2003 13:41
pic: Last year was FIRST water... CD47-Bot Extra Discussion 14 14-04-2003 23:36
pic: Never seen of! Never heard of! The secret revealed! CD47-Bot Robot Showcase 5 06-03-2003 15:49
