Go to Post Boy you guys try to make my job harder every year. - Al Skierkiewicz [more]
Unread 16-02-2005, 16:26
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
pic: 179 Swampthing 2k5 innards
www.179swampthing.org
Unread 16-02-2005, 16:30
greencactus3 greencactus3 is offline
occra 23.
AKA: ryo
None #1481
greencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to allgreencactus3 is a name known to all
Send a message via AIM to greencactus3 Send a message via MSN to greencactus3
Re: pic: 179 Swampthing 2k5 innards
wow. looks nice and beefy and green. like how you guys have the frame inset for your compressor. guessing the battery might be that low too. wondering what those legs are for and what that center is gonna be supporting. like how you guys offset the center wheels outwards too. so this is another way to help a 6wd turn. hmm. just curious. whats that angle? does it have a specific reason? other than it looks sweet and maybe stronger and compact?
Unread 16-02-2005, 16:31
AJunx AJunx is offline
AJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to all
That is incredible.
Sidenote: What did you use for tire treads?
Unread 16-02-2005, 20:36
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Conveyor belt, I love octagons!
Hows my searching? Call 1-800-Green-Dots
Unread 16-02-2005, 20:48
remind me guys how you have time to paint your bots??? and be finished... u'r not on s.p.a.m. time that's for sure
it looks very nice again guys
Unread 16-02-2005, 21:05
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
6 wheel drive, hmmmm.....
What sort of pushing power do you get?
Unread 16-02-2005, 21:15
george56 george56 is offline
the Beast of 116
AKA: Big G
FRC #0116 (epsilon delta)
george56 has a spectacular aura aboutgeorge56 has a spectacular aura about
Send a message via AIM to george56
is it just me or does it look like its one big piece of metal? anyways it looks awesome! nice job guys!
Unread 16-02-2005, 21:17
abeD's Avatar
abeD abeD is offline
FRC #4707 (Mentor FRC#4707 Alumni FRC#710)
abeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to beholdabeD is a splendid one to behold
...I think they had it waterjetted...and I know that it pushed a pretty big guy around in high gear...I am sufficiently scared...
Penn Class 08
Unread 16-02-2005, 21:27
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
Thats just awesome, I love the green.. If it was all water jetted how big was the original piece that it came from?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 16-02-2005, 21:44
the Beast of 116
AKA: Big G
Me too! it looks like it could push anything out of its way!
Unread 16-02-2005, 22:19
Swampdude's Avatar
AKA: Dan Quiggle
This octagonal shape is credited to Warren Boudraux of team 180. The idea is to reduce the surface area that other bots can pin you with. If you have long flat sides, other bots can square off on you to hold you on a wall easier and redirect your heading also. This shape makes it much easier to rotate out of a pin hold and keep moving. Also each flat side has a bumper plate with noodle foam between it and the chassis to reduce the shock loads sent through the frame on collisions. Our electronics module is also floating on rubber to reduce shock loading. Then the cover completes the safety net over the electronics. It should be able to take a heck of a beating. Also limiting the amount of shock we would put into other bot's apon collision.
Those piston arms are for dropping the hanging tets in auto, also used to upright the bot if it fell on it's side. Also they collect human player tetras, so we can carry 4. But tonight we took the back 2 off, I don't think we'll need them. They work good for scoring human tets under/inside goals if we choose to do that any. They also increase the size of the bot during autonomous (making it easier to find the opponent) in order to disrupt vision tet caps.
Unread 16-02-2005, 22:21
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
That is most definitely not all one piece. You can see welds all over the place.
Looks great though, can't wait to see this thing in action (arm included)
2001-2004: Team 100
2006-Present: Team 254
pic: 179 Is riding on 4.5" Tytus Gerrish Extra Discussion 17 14-06-2006 23:44
pic: 179 Swampthing 2k5 Swampdude Robot Showcase 18 18-02-2005 07:35
pic: 179 Swampthing 2k4 CD47-Bot Robot Showcase 30 29-02-2004 22:11
pic: Team 179 Playing Field CD47-Bot Extra Discussion 4 08-02-2004 22:28
