Re: pic: Nitrous Oxide
whats with the hot glue? or what ever that stuff is?
and seems you are going to multiposition? not quite done it seems lol what are those 3 switches at the top left do? and where are you takeing the exhausts? i understand up to the single solenoid to multi position but after that,, are you going to blow air into your motors or sumthing? looks nice but you have your double in the center. which might mean itll take a longer tube to connect to your cylider. which means more waste. you want the tubes from your solenpid to your cylinders as short as you can. for efficiency. |
| pic: team 909's robot - pic 2 | Brad Lanpher | Robot Showcase | 8 | 16-02-2005 08:34 |
| pic: 294's First Inventor Robot (pic 1)... | CD47-Bot | Robot Showcase | 4 | 10-03-2004 19:34 |
| pic: Team PIC of 354 Westinghouse HS | CD47-Bot | Robot Showcase | 4 | 29-02-2004 12:15 |
| TCP/IP on a PIC | Venkatesh | Electrical | 1 | 18-11-2003 21:00 |
| pic: Another pic of Team 930 | CD47-Bot | Robot Showcase | 7 | 25-02-2003 21:07 |
