Re: pic: Sprocket mounting for window motor
FYI-
A finding about the Nippon Denso Motors- we used the ND motor as the axis of an articulated arm where the ND gear drives a larger gear in a simple gearbox. However we find that the housing of the axis of the motor is weak and tends to crack through the housing after a while. We remedied the situation with a cleat and a little reinforcement of the shaft so it won't torque so much. Hopefully it will last well enough and after about a thousand trials over the past three days I think we are set. WC ![]() |
| pic: 870 Motor Mount | CD47-Bot | Robot Showcase | 9 | 27-04-2004 11:55 |
| pic: 571's new gearz loose weight | CD47-Bot | Robot Showcase | 24 | 16-04-2004 16:35 |
| pic: Fischer Price motor are very powerful | CD47-Bot | Robot Showcase | 15 | 17-03-2004 20:22 |
| need window motor pic!! | Rickertsen2 | Motors | 3 | 04-02-2003 21:50 |
