Go to Post dont be afraid of new technology. embrace it and experment with it figure out the problems on the way and then tell us about it so it gets easier. - Tytus Gerrish [more]
Unread 22-02-2005, 03:06
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: pic: Sprocket mounting for window motor
Well since I'm up past 2:45am on the Tuesday morning before ship putting it in the box; I might as well help you out.
First you need a 5/32 drill bit and then you can just follow this drill pattern once the sprocket is centered in the mill.
You will probably need a lathe to bore the hole to the size that the hole is in the plastic coupler.
I do not remember what size it is.
You will also need to chamfer the edges of the holes because of the way the gears are shaped on the motor.
If yah need anything just let me know being that I made them.
Sorry for the not so good drawing; I guess I should also specify that my units are in inches too.
Name:	sprocket gear pattern.JPG
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
pic: 870 Motor Mount CD47-Bot Robot Showcase 9 27-04-2004 11:55
pic: 571's new gearz loose weight CD47-Bot Robot Showcase 24 16-04-2004 16:35
pic: Fischer Price motor are very powerful CD47-Bot Robot Showcase 15 17-03-2004 20:22
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
