Go to Post Once you have reached overkill, more is not useful. - DonRotolo [more]
Unread 23-02-2005, 09:58
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: pic: The programmer needs some alone time with the robot!
Originally Posted by Bharat Nain
Programmers do need time alone to program autonomous mode. I wish FIRST created a rule to leave programmers alone while they're programming autonomous
But you'd still have to figure out how to prioritize access to the robot. Competition between mechanical/electrical and software tasks is probably our biggest hurdle when trying to get everything done on time.
If the programmer is left alone and if there's something mechanically or electrically faulty, his time will be wasted. Or, worse, he'll try to fix it himself.
This year I wrote an autonomous mode interpreter. It took longer than making a simple autonomous routine, but it paid off. The robot's autonomous actions are controlled by a simple text script, which anyone can write. Once I got the interpreter to make the robot perform repeatably, I stepped aside. The other mentors and team leaders took care of the scripting.
Unread 23-02-2005, 10:35
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
I for one would be interested in seeing the interpeter!
Post the code (after the competition if you are leary).
Phil
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
THIS TIME TEAM 438 BALANCING ROBOT archiver 2001 1 24-06-2002 01:01
How long should production time be??? archiver 1999 4 23-06-2002 23:16
