Go to Post There is no offseason. - Jeff Rodriguez [more]
Unread 25-02-2005, 12:40
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Re: pic: Team 1640's '05 Bot
Originally Posted by coastertux
Those holes are just the mounting!
PhatMike, how would you recommend covering up that tubing? Also, what can we do at the compeition to secure the kit frame? We just used their bolts and lock washers/nuts.
I'd take a bottle of loctite and squirt a little on each screw, and screw it back in. FIRST doesnt like you leaving stuff on the field. You should use loctite on all your setscrews (they WILL come off) anyways.
As for the hose, I dont know what you could do. There just has to be a better way of attaching it to that arm other than what you have in the picture. If your arm was in the same match with us, and we got tangled, it'd get ugly. Those hoses are extremely vunerable, and if they're damaged/removed in the match, your basically useless.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Renovating a Team av11d Team Organization 2 18-04-2004 20:06
pic: Team 151's bot CD47-Bot Robot Showcase 7 06-03-2003 09:41
Disqualifications archiver 1999 13 23-06-2002 21:53
