Go to Post There are times when all of us - myself included - need a virtual *poink* to the back of the head and someone to say "wake up and stop behaving like a three-year-old." - dlavery [more]
Unread 25-02-2005, 15:26
JessR JessR is offline
#0571 (Team Paragon)
JessR will become famous soon enough
pic: 571-Team Paragon 2005 trannys...
2004 UTC New England Champions with 716 & 230
Engineering Lead
Team Paragon #571
Unread 25-02-2005, 15:40
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: pic: 571-Team Paragon 2005 trannys...
Sweet, how does it shift?
Light, neat, simple!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 25-02-2005, 16:06
You (of all teams) should know! Thanks.
Engineering Lead
Team Paragon #571
Unread 25-02-2005, 16:10
AKA: Bradley Rigdon
Thought so!
I just did not want to come out and say "wow nice way to use ball bearings to shift" and not have it be so...
So what do you think about this method of shifting?
Unread 25-02-2005, 16:13
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
That PC board probably has to do with that hall effect sensor. I take it you use the hall effect sensor to determine how fast the tranny is going and when you need to shift. Looks sweet.
See you in DC!
Unread 25-02-2005, 17:14
Levin571's Avatar
Levin571 Levin571 is offline
DC Regional VC
no team (Former Team Paragon member)
Levin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud ofLevin571 has much to be proud of
Send a message via AIM to Levin571
To add a little more info, each one weighs 5 pounds with a "chippy" and without the chippawa each one is i believe 4 or 5''x 6''x 1 1/2'' thick
We decided to go against the bigger is better theory and go for our usual "If it still works it's not complicated enough" tactic.
2012 FIRST DC Volunteer Coordinator
2003-2005 Driver/Operator
2006 Scout
2004 UTC New Englands Winner
Co-Founder of FF
Unread 25-02-2005, 17:47
Engineering Mentor
FRC #0254
It looks cool!
The only thing worrying me is the piston. It certaintly does not look like a bimba-order-form equivalent. Not that it is a hard thing to change, I just thought I would give you guys a heads up before your first competition. If there is something I missed, please forgive me.
Otherwise good job!
-Travis Covington
Unread 25-02-2005, 18:00
Lea DeFoote Lea DeFoote is offline
Lea DeFoote is an unknown quantity at this point
Hi Travis-
I'm not sure what you mean by "bimba-order-form equivalent", but the air cylinders are Bimba brand.
-Tom
Unread 25-02-2005, 18:21
Originally Posted by Lea DeFoote
Hi Travis-
-Tom
I think what Travis is looking at is the air fitting coming out the end of the cylinder rather than the side. I have never seen this before. Where did you get this clyinder?
Unread 25-02-2005, 18:25
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Is that LAN cable I see? Or some sort of smaller equivalent?
Maybe phone line? But does phone cable come with a yellow jacket?
Unread 25-02-2005, 18:37
1. Sandrag- the cylinders came from ...Bimba.
However thanks Travis - Indeed only the "DP" (clevis) end style cylinders are on the Pneumatics order form, so looks like Mr. Charney will go air shopping next week....
2. Elgin - it's not a LAN cable or equivalent .. it's HALF a Lan cable.
(You can take a wild guess at what symmetric location the other half is)
Thanks for the good feedback everyone..
Engineering Lead
Team Paragon #571
Unread 25-02-2005, 18:41
Engineering Mentor
FRC #0254
Good to hear. It really is just another hoop to jump through as the style you have really isn't functionally better than the DP style. We are actually having to do the same thing as one of the pistons we were shipped (ordered the correct one from Motion industries) is also not the DP style. They are resolving the problem for us, but it brought about some last minute part fabrication to get the one we did have to work with the design that called for the correct style. Oh well.
Goodluck to you guys at competition!
-Travis Covington
pic: 2005 Team Fusion (364) Robot bhweezer Robot Showcase 7 20-02-2005 14:03
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
The calm before the storm / Tips for 2005 and beyond. Elgin Clock General Forum 2 07-01-2005 13:55
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
