Go to Post Thank God for the Technokats. - Koko Ed [more]
Unread 02-27-2005, 01:24 AM
Scythe's Avatar
Scythe Scythe is offline
That guy with the cape...
AKA: Scott
FRC #0180 (S.P.A.M.)
Scythe is an unknown quantity at this point
Send a message via AIM to Scythe
Re: pic: 1276 - Kaizen Blitz 2005 bot
I'm just going to assume that you can hold the tetra better than the arcade version?
Unread 02-27-2005, 03:52 PM
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Yes. The pneumatic cylinder keeps it closed. You can't pull it out of the claw actually.
Originally Posted by chantilly_team
How do you manage your center of gravity? What if some bot hits you?
Most of the time tetras are contained on the base. Also when there are tetras in the air there are usually one or two or three 8 lb tetras on the base. They are only in the air near the goal. Also in case anyone wanted to do some scouting heres the full spec sheet:
2 front omni wheels and 2 back 8" back wheels (not omni wheels)
Max speed 9fps
Able to place the 7th tetra on the center goal.
Can carry 2 tetras in the claw and a stack of 4 on the base
Can load 4 tetras from the manual and deploy them on a nearby goal in 45 secs.
Autonomous Mode-Able to stack the tetra given to each alliance at the beginning of the match.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 02-27-2005, 06:48 PM
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
And the mentors said it couldn't be done! That's exactly the type of claw I came up with at the beginning of the season! Rrrggghhh....
Oh well... at least we saved some weight by not having pneumatics...
pic: 2005 Team 1549 Rookie Pic Eupher Robot Showcase 7 03-01-2005 11:20 AM
pic: S.P.A.M. 2005 Bot tiffany34990 Robot Showcase 26 02-26-2005 08:34 PM
pic: Team 107 Bot Pic 01 brent_107 Robot Showcase 13 02-26-2005 02:49 PM
Team 95 Bot pic, this thing is crazy! JamesCH95 Robot Showcase 0 02-22-2005 01:53 PM
2005 Beantown Blitz! Erin Rapacki Off-Season Events 1 11-01-2004 08:35 AM
