Go to Post Throw the programmers (or freshmen with duct tape depending on the state of your robot) in the trailer with the robot for the ride between events. Problem solved. :D - ASD20 [more]
Unread 26-02-2005, 20:13
brownster brownster is offline
#1392 (Team Kinematrix)
brownster is an unknown quantity at this point
pic: Team 1392 Kinematrix's Robot
Unread 26-02-2005, 22:27
chantilly_team chantilly_team is offline
chantilly_team is an unknown quantity at this point
Re: pic: Team 1392 Kinematrix's Robot
pretty complex.
Unread 26-02-2005, 23:25
AJunx AJunx is offline
AJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to allAJunx is a name known to all
That is awesome. I'm a huge fan.
Question: How many tetras can you stack at once?
-Andrew
Unread 26-02-2005, 23:29
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Having wasted 24+ hours on the camera...
NICE CAMERA MOUNT
(we took it off the day before we shipped, but weren't wise enough to put it back on when we did ship, so we're going to put it back on as soon as we get to regionals)
Unread 27-02-2005, 00:01
Sterno Sterno is offline
AKA: Andrew Stern
FRC #0766
Team Role: Electrical
Sterno has a spectacular aura aboutSterno has a spectacular aura about
Send a message via AIM to Sterno
Very interesting..what's the center tower for? stability? How far up can you reach?
Unread 27-02-2005, 12:21
The center tower's for mounting the pulley that raises the scissors and for stability, we can reach about 10 feet in the air...but we kinda broke our scissors just before we shipped the alminum gave..so we're thinking about reenforcing with other material..any suggestions?
Unread 27-02-2005, 14:07
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
how did it break? just bend? or snapped? and in what direction? What were the dimensions of the aluminum you were using before?
Unread 27-02-2005, 14:37
it actually snapped..the scissors have this weird place they got stuck...it was 1/4 or 1/2 inch square aluminum tubing..not sure..but ya we nee something close to the same dimensions but stronger
Unread 27-02-2005, 15:53
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
steel if you have the weight, titanium if you have the supply...same for carbon fiber...but isn't daydreaming nice?
Anyway...more realistically...bosch (spelling is probably wrong) Al would be close to the weight and the internal structure on it might help it hold up a little better...
How much weight do you have to work with?
But really honestly if it got "stuck" someplace you would probably be better off fixing it so it doesn't get stuck than getting a new material. A flaw like that could show up no matter what material you use...plus issues like weight and center of gravity...or even if it does hold and you still get jammed mid-match you could become useless.
Unread 27-02-2005, 21:35
Chesteves's Avatar
Chesteves Chesteves is offline
AKA: Chris Esteves
#1002 (Circuit Runners)
Chesteves is an unknown quantity at this point
hmm i would suggest extruded aluminum, once again if you have the weight. very nice stuff i might add, we used it on our last yr's robot.
Unread 27-02-2005, 21:44
Actually we really only have like 5-7 pounds to work with..well from our scales..but thanks for the ideas
Unread 27-02-2005, 21:53
RogerR's Avatar
RogerR RogerR is online now
AKA: Roger Riquelme
FRC #3844 (Wildbots)
i would advise against using extruded aluminum. a while back, a white paper was put up that compared the strengths of various profiles (square tubing aluminum and aluminum extrusion being two) and square tubing came out being much weaker. as others have said, the best option might be to go with a stronger material, such as steel, or maybe thicker wall diameter, if possible.
<edit> link for afore mentioned white paper </edit>
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 27-02-2005, 23:09
Thanks very much, we were already thinking of steel too..but might have to only replace a few pieces (the key pieces) cus of weight limit
Unread 27-02-2005, 23:30
Katy's Avatar
just to get a better feel of things...how much does the current structure weigh in Al?
Unread 28-02-2005, 18:51
the whole scissor structure weighs about 16 pounds
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
