pic: The shadow claw--claw
Re: pic: The shadow claw--claw
I love that you made it out of wood, I bet when it closes it sounds like MOE sticks .
They look great, good luck this year! |
Is that pneumatic hose/coupling going up the arm legal?
looks like u can pick up a car(joking) with the psi from that hose
-dave |
Wow, good job team 1559! Your claw looks absolutely amazing. I love the color <3.
<R36> Additional Parts must be generally available from suppliers such that any other FIRST team, if it so desires, may also obtain them at the same price...
Our parts are NOT on the NOT allowed list, and nowhere have we found, to our knowledge, that we needed to use only the parts on from the kit. As long as it is not "hazardous" or otherwise deemed illegal, and it is a COTS part, we see it as perfectly and legitimately legal. A coiled tube is NOT banned from the pneumatics manual or anywhere else. Hope this clarifies any issues. And our 25 inch cylinders--in case anyone was wondering--are from Parker-Hannifin. "additional cylinders can also be purchased through a Bimba or Parker-Hannifin Distributor." We got ours from Parker, so they are perfectly legal. |
Actually a coiled tube, if not made by yourself, has been banned. It was answered in the Q and A. Also, you can not use that size pneumatic hose seen in the lower left of the picture. Edit: Your answers are located here http://www.chiefdelphi.com/forums/sh...26&postcount=3 Last edited by BoyWithCape195 : 01-03-2005 at 18:40. |
Q: In reference to 1609, Are we limited to ONLY using the 20 meters of pneumatic tubing provided in the Kit of Parts? Therefore, we CANNOT use equivalent tubing with equivalent specs, but different colors. Am I correct in this assumption? A: Correct. Q: In reference to 1609 and 1641 can we use SMC tubing with the same part number as the tubing that came in the kit only in a different color, much like electric schematics use different colors. If not can we spray paint the tubing? A: The tubing in the kits was at least 2 colors... blue and black. There may have been additional colors. The tubing should be SMC tubing with TIUB07 on it. I believe those two questions sufficiently prove that you cannot use that tubing. And as for your cylinder, see here- http://www.bimba.com/techctr/first_free_frm.htm 24" stroke is the largest you can have. |
#10
Thank you but this is between us and the judges.
#12
We're not just trying to be asses and get your robot DQ'ed. You can take whatever you want up with the "judges" but we've just shown you what the rules are. Hopefully you can fix this issue without losing too much time at your regional. |
#13
and everyone else, this is a rookie team, most experenced teams have trubble using the correct parts sometimes, so remember be nice you were all once rookies before to. |
#14
Just some friendly unsolicited advice. |
#15
| pic: The Shadow Claw | bradleym1559 | Robot Showcase | 8 | 27-02-2005 15:10 |
| pic: Team 222's 2005 Claw | henryBsick | Robot Showcase | 3 | 23-02-2005 21:48 |
| pic: X-WhAAAt's claw | Koko Ed | Robot Showcase | 5 | 22-02-2005 10:24 |
| pic: 1241 Robot - Shadow | CD47-Bot | Robot Showcase | 2 | 11-04-2004 13:16 |
| pic: Claw of doom (571) | CD47-Bot | Robot Showcase | 10 | 31-01-2004 08:49 |
