Go to Post "I'm not teaching you math, I'm teaching you how to think. Hopefully that'll be useful to you someday..." - Karthik [more]
Unread 03-03-2005, 12:56
TriggsJr TriggsJr is offline
US FIRST made me an Engineer
None #0173
TriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to all
Send a message via AIM to TriggsJr
pic: Rage 173 cross section of robot in SolidWorks
Unread 03-03-2005, 12:57
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Re: pic: Rage 173 cross section of robot in SolidWorks
I think you're pulsing electromagnets to slide the arm.
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 03-03-2005, 14:50
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
Dave
Nope, that would be nice though.......
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 03-03-2005, 15:02
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
It looks to be something similar to the tape measure extension mechanisms seen last year or the mechanism used for a car antenna. A flexible, or at least flexible in one axis so that it can be coiled member with an OD only slightly smaller than the ID of the tube its in is pushed. The tube supports it to prevent it from buckling. It looks like that purple thing that folds back twice is this member. If I'm right, I'm curious what exactly it is.
EDIT: No, I'm stupid, this is not the mechanism, or at least the purple thing isn't the extension member because it isn't extended but the arm is.
Team 1257
Unread 03-03-2005, 16:11
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
The purple thing is an industrial wireway, like the E2 mini from Igus. I am figuring that the reason that this wireway is not extended in this CAD view is because it is difficult to show the wireway in extended and retracted positions. This file simply shows the wireway in a retracted position and the arm in an extended position.
The wireway was modeled in the retracted position, and sized to fit. Then, to show this view, the designer decided to extend the arm without making the significant effort to model the wireway in an extended position.
At least, that is how I see it.
But.. on to the topic at hand... this is a great design. I am excited to see how it works, and will be eager for a up close view in Atlanta.
Andy B.
Unread 03-03-2005, 21:36
Fold em oval!
Ah, so I'm right, or at least Andy Baker thinks so. And I had thought it was a wireway, too, though I didn't know what it was called. (I have seem the same stuff sticking out of a CNC machine at the place I intern at.) I'm also very interested in seeing the real thing. I have always thought this design is underused. Seems like such an effective way for powering a telescoping device.
Team 1257
Unread 03-03-2005, 22:00
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Yes, you are right.
I saw it at the UTC scrimmage... I had never seen anything like it before.
I would have posted the answer, but I didn't know the stuff was called "wireway"....I learn something new every day I guess.
Nice job RAGE, your bot looked great at UTC! That arm is fast and moves nicely.
-- Jaine
Florida Institute of Technology
Ocean Engineering, '12
Unread 04-03-2005, 09:17
None #0173
heres the links of it running.
http://www.rage173.org/video.php?catid=28
Unread 04-03-2005, 18:26
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
judging by the coloring, it sorta looks like a light saber, so i'd say the force.
Unread 13-03-2005, 22:38
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Okay...
This is THE COOLEST FIRST design I've seen in a long time.
I was shown this on Thursday at UTC, and have been smitten ever since.
Andy,
You got it 1/2 right.
For those who haven't seen it yet -- RAGE actually uses the cable carrier to extend and retract their arm. I won't steal ALL their thunder, and post the details -- perhaps Triggs can enlighten everyone.
It is SPECTACULARLY cool. Soooo smooth, soooo simple.
After fighting with cable/pulley's last year for our extension, I am AMAZED by how simple and effective this is.
The best part? It manages their cables/pneumatic tubes WHILE is drives the arm!
Seriously --
This entire robot is a work of art. The sheet metal arm design is one of the best I've ever seen on a FIRST robot. Combined with their great end effector, and this innovative extension, it is truly an incredible machine.
RAGE--
Kudos on an incredible machine. I was SHOCKED when you didn't win a technical award at UTC. You've definitely inspired me. (Not always a good thing!)
Everyone Else--
Go check this thing out. Seriously, if you get the chance, take some time to go visit 173's pit. It is worth taking a walk over.
Again -- Kudos to 173!
John
Unread 14-03-2005, 01:38
jpsaul7usa's Avatar
jpsaul7usa jpsaul7usa is offline
Reslife/FIRST/Disneyland Junkie
None #1212 (The Holy Hamsters)
jpsaul7usa is just really nicejpsaul7usa is just really nicejpsaul7usa is just really nicejpsaul7usa is just really nice
Send a message via AIM to jpsaul7usa
Question Re: pic: Rage 173 cross section of robot in SolidWorks
Could somebody explain this contraption? I haven't the slightest idea what the picture is showing. What I'm hearing is that it's better than a winch, and that's definitely something I'd like to hear about. And how does it manage the pneumatic tubing and cables?
Boeing has its Phantom Works; Lockheed Martin has its Skunk Works; 1212 has our Lucky-if-it Works.
My Website; Team 1212; DOX; NAU(Tinsley Hall Resident Assistant, Golden Key Webmaster; SAACS; NRHH)
2003 AZ Regional 5th Seed Quarter-Finalist (Rookie Year- Thanks 57 and 624!!!)
2004 AZ Regional Leadership in Control Award, AZ Regional Champion (Woohoo! Thanks 330 and 585!!!), Newton 23rd Seed
2005 AZ Regional Delphi Driving Tomorrow's Technology Award, AZ Regional Finalist (Thanks 991 and 987!!!)
The Holy Hamster Motto: It's only temporary... unless it works.
Unread 14-03-2005, 10:03
None #0173
Thanks John for the complement !!!
I was very shocked we didn’t get a design award. With in our peers we were picked first for an Alliance partner. This was our goal, because the qualifying rounds have too much luck involved with them. I was very happy to take 2nd place in the UTC regional. We have one more regional and then the national to show at. So maybe we can pull out a win somewhere. But all of our goals for design were met and went a little farther then we expected. For next year if theirs lifting to do again you’ll definitely see this unit again.
Ok the design is all based around an item I use all the time at work. Its called cable chain, others call it wire way, or cable way. Cable chain was designed to have cables and hoses run through it. The chain is then connected to a stationary object and the other end is attached to an object that moves back and forth. As the moving object goes from one end to other the chain either unrolls or rolls back up. This is all the product was designed to do. The chain has this other property that the chain is stiff in one direction and the other the chain rolls up. Kind of like a Fat Max tape measure rolled out correctly the tape measure is stiff. Flip the tape over and the tape falls. This concept allows the tape measure to be rolled up. So I said if I can feed this chain into a set of telescoping tubes with a custom drive sprocket I can push the tubes out and pull them back in. And a bonus is I can run all the pneumatic lines and sensor wires right in the chain making a very clean setup.
We were very afraid the chain links would not take the pushing stress. So we prototyped an arm with the chain I wanted to use. As we ran the prototype we were all like this is the greatest thing since sliced bread. No more wire cables and pulleys or camper lifts.
Unloaded our arm can rise a total from ground to the end 13 ft in 4.8 seconds. Now we found at UTC you never have to reach that high most times its only about 10 to 11 feet.
The arm is made of 1/16 aluminum that has been laser cut and cnc bent. All sections of the 1/16 material took up a 4’x6’ sheet. A smaller tube was put on one side of the telescope to collect the cable chain it was made of 1/32 aluminum. The whole arm with motor and end affector weighed around 23 lbs. This gave us a great center of gravity. We have never tipped the machine over in competition or practice.
I offer a challenge for next year for some team to use this method. A Company called Igus makes the chain. Their on the web. It sure beats the making all those pulleys up.
Unread 14-03-2005, 10:22
This makes sense to me. If we do a telescoping arm in the future, this is the direction I would like to go... we would call it a "Rage arm".
Great job Rage, and thanks Triggs for showing to us.
Andy B.
Unread 14-03-2005, 12:19
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Igus makes lots of interesting stuff. We got them as a sponsor this year so our entire telescoping arm is made out of 6 sections of their linear bearings. The stuff is awesome, smooooooooooth, and cantilevering a 12 lb tetra 4 feet out doesn't bind it up too much.
Alex
President
Team 1072 Harker Robotics
Unread 15-03-2005, 17:15
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
very impressive. Cant wait to see it in person at Annapolis and Atl! Hopefully we wont be the victim of it. Better yet, hopefully well be on its side(whadda ya say to pickin us for the elims? )
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
XCats - robot pic on our website archiver 2001 0 24-06-2002 01:06
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
