Go to Post As a wise man from PA once said to me "Changing the culture is hard work." - RoboMom [more]
Unread 09-03-2005, 13:20
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
pic: 1097 Direct Drive 01
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 09-03-2005, 13:21
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Re: pic: 1097 Direct Drive 01
woah,was it worth having no chains?
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 09-03-2005, 13:38
Alex Cormier's Avatar
www.TwoPencilDesigns.com
FRC #1405
whats the weight comparison to chains and sprockets? also does that have any advantages like less moving parts or more giving? interesting
Unread 09-03-2005, 13:40
1. Very cool. I'm impressed.
2. What you have is a shaft-drive system. "Direct drive" in most places I've seen it would have the power module (in your case an electric motor) directly driving the wheels without gear (or belts with pulleys) reduction. I do not believe "direct drive" is the best description for your bot.
3. Did I say I thought it was cool? I like the way it simplifies the packaging of the drivetrain.
Unread 09-03-2005, 13:42
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
Ouch says the inefficiency meter. Have you guys calculated the losses in all those 90 degree reductions? How are things set up inside that gearbox, is it all straight cut spur gears? Even still, it is really cool and unlike anything I have seen on a FIRST robot yet. +1 creativity points.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 09-03-2005, 14:51
Ooo. I like. Very unique. Are those driveshafts aluminum? Also, what is the efficiency on mitre gears?
Unread 09-03-2005, 15:50
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
It looks really pretty, but as SpaceOsc asked, why?
Sanddrag, bevel gears (I believe that is the more common name) have similar efficiency to spur gears (95%+) because they do not have any surfaces sliding across each other (like in a worm gear).
Team 1257
Unread 09-03-2005, 16:33
My reason would be there is no possibility of throwing chains or broken chains. Also, my favorite reason for it is no chains to tension. And there's also the "it's really cool and hasn't been done before" aspect.
Unread 09-03-2005, 17:52
AKA: SonKenshin
Well, to answer the efficiency question, it's very efficient. The miter gears are aligned within .0005" and transfer the power better than chains. We have had chain problems before. Last year we threw Motorcycle (40 gauge) chain many times, so it removes the need to tension or worry about chains. We went through the entire sac regional without damaging it at all. The ony thing we had to do was check the set-screws to be safe.
As for the drive-shafts, they are .049" wall steel tubing.
As for the efficiency on the miter gears, they are just as effieient as straight-cut spur gears.
We lightened all the gears in the gearbox with 6 holes in each, similar to the wheels if you have seen them. Overall, the entire robot weighs 106.8 lbs, so we have no weight concerns.
And, as Sanddrag said, we did it mainly since no one else has done it.
My mechanic told me to tell you that there are 46 bearings and 42 set-screws in the drive-train.
And as for shaft-drive/direct-drive, we've always seen shaft-drive as a sub-set of direct-drive.
-Tony K
Unread 09-03-2005, 17:56
How is rotational load transfered to the U-joints? If the driveshaft was solid, I would put a keyway in it but since it is a tube I'm wondering how you did it. Did you put a pin through? .049 is pretty thin, thats awesome.
Unread 09-03-2005, 17:57
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
i saw it in your pits, very cool and unique. Congrats on doing something unusual!. And is that the kit gearbox?
Harker Robotics:1072
http://www.harker-robotics.org
Unread 09-03-2005, 18:09
AKA: SonKenshin
The OD of the U-Joints were turned down to within .005" of the ID of the steel shaft. We then put set screws all the way through and have had no problems with them. Eventhough, we are still going to replace all 42 set-screws on thursday at SVR.
As for the gearbox, it is about the same ratio as the kit gearbox, but we couldn't use the kit gearbox due to the way we had to lay it out. As you can see, we needed the driveshaft to go straight through the gearbox and the kit version wouldn't allow for this. We therefore also had to put the CIMs across from eachother. This is useful in that neither side will be more powerful since in either direction, you have one motor running forward and one running backward.
-Tony K
Unread 09-03-2005, 18:51
Projectchon's Avatar
Projectchon Projectchon is offline
AKA: William Lei
FRC #1009 (Vainer Robotic)
Projectchon can only hope to improve
where did you guys get the U join?
Team 1009
Unread 09-03-2005, 20:48
The OD of the U-Joints were machined down to within .005" of the ID of the steel shaft. We then put set screws all the way through and have had no problems with them. -Tony K
Oh okay. I was envisioning the tube going into the U joint, not the U joint going into the tube. Very clever! I hope it continues to work out well for you and maybe we'll give it a try next year!
Unread 10-03-2005, 00:07
AKA: SonKenshin
If you want to give it a shot, I'll see if I can get my mechanic to give me all of the blueprints and I'll scan them for you.
pic: kiwi drive wheels CD47-Bot Extra Discussion 3 24-08-2004 21:39
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
direct Drill motor drive wrong or right rcubes85 General Forum 6 11-02-2003 18:11
