Go to Post You will find we are more talkative in about 5 1/2 weeks. ;) - mrnoble [more]
Unread 17-03-2005, 03:44
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
White Paper Discuss: Spreedsheet to Calculate the Ranking of Teams
Thread created automatically to discuss a document in the White Papers.
Spreedsheet to Calculate the Ranking of Teams by Joe Johnson
Joseph M. Johnson, Ph.D., P.E.
Team #88, TJ2
Unread 17-03-2005, 04:06
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: White Paper Discuss: Spreedsheet to Calculate the Ranking of Teams
Hi Joe, I found a couple of problems.
Besides entering the teams in the "TEAM NAME DATA" worksheet, you must also enter the team number in the "Team Summary" worksheet. That's relatively easy to fix by changing A2 on the "Team Summary" worksheet to ='TEAM NAME DATA'!A2 and dragging down.
You seem to be making the same mistake calculating RP as I initially did. The winner should get the lower of the unpenalized score of the winner or loser (per team update 15). Lets say Blue scores 19 and Red 25, and each has a 10 point penalty. The net score is Blue 9, Red 15. The losers RP is the losers net score, 9, which you get correct. However the winners RP is the lower of the teams raw score, which is 19. You currently have it at 15.
To fix this, change Z3 to =IF(P3="X",IF(S3=T3,T3,IF(S3=R3,MIN(X3,Q3),R3)),"-") instead of =IF(P3="X",IF(S3=T3,T3,IF(S3=R3,MIN(X3,R3),R3)),"-") and drag down
Personally, I like the way you had it better as a ranking system (the lower of the winners penalized score or the losers unpenalized score) but that's not the way it is stated in update 15.
With those changes, your spreadsheet produces the same results as my spreadsheet and SOAPs database
Unread 17-03-2005, 06:00
Rookie Year: 1997
One more:
It doesn't look like your spreadsheet calculates the highest match score to use as the tie breaker if the RP are equal.
Unread 17-03-2005, 06:57
AKA: Dr. Joe
FRC #0088 (TJ2)
You are right, I just got sloppy at the end and missed this. This was page was the relative easy part and I was tired...
I have to admit that I have NOT read the rules on this one. BUT, folks I know and trust have told me this is what FIRST intended by the rules whatever they SAY and that this is how they want the ranking implemented.
I will see what I can find out...
Joe J.
Team #88, TJ2
Unread 17-03-2005, 06:59
AKA: Dr. Joe
FRC #0088 (TJ2)
One more:
This is also because I didn't read the rules! Frankly, I just added the random tiebreaker column because the RANK function behaves better without ties.
I will have to think about how to implement this in my setup...
Joe J.
Team #88, TJ2
Unread 17-03-2005, 09:27
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
We're implementing this system as a backup at Boilermaker.
Anything else we need to know, besides the two tweaks previously mentioned?
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 17-03-2005, 09:44
AKA: Dr. Joe
FRC #0088 (TJ2)
Use the New one HERE.
Fixes problems, implements highest QP points as the 3rd tiebreaker
1 Record
2 Average QP
3 Highest QP
4 Flip of a coin
Did NOT implement Joe Ross' suggestion of change to how QP's are given out when an opponent's penalties cause a loss (i.e. the losers would have won if they went penalty free). The winner's QP points are limited by their OWN QP points.
I have not read the rules, but I understand that this is how FIRST wants the points calculated.
Joe J.
Joe J.
Team #88, TJ2
Unread 17-03-2005, 11:39
Rookie Year: 1997
1 Record
2 Average QP
3 Highest QP
4 Flip of a coin
In talking with Kenny Ardizzone, we both believe the rules call out the highest match score (the highest score that team had after penalties) rather then the highest QP.
Can you check that with your contacts as well?
Edit: also, the 30pt penalty field was removed, was that intentional?
Edit2: I can't read, it was intentional.
Unread 17-03-2005, 11:43
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Just sent Joe a PM/Page. The current spreadsheet has a broken implementation of the Highest QP Calc. Right now it's basically just finding the highest QP of a team's first two matches.
Unread 17-03-2005, 13:04
AKA: Dr. Joe
FRC #0088 (TJ2)
Thanks Kevin. Fixed it HERE.
Joe J.
Team #88, TJ2
Unread 17-03-2005, 13:21
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
From The Manual, bolding added for emphasis.
Originally Posted by 2005 Manual, Section 8.3.7
The Scoring System will use the following Ranking Method:
• Teams will be broken into Tiers based on their Qualifying Score. A Tier is made up of all teams with the same Qualifying Score.
• Within each Tier, teams will be sorted by their Ranking Score. Note: Because your Ranking Score is derived directly from the Match Scores of the losing alliances in the matches you play, it is in your best interest to support your opponents and win by helping each alliance score as many points as possible.
• If any teams within a Tier have the same Ranking Score, they will then be sorted by their Highest Match Score.
If any teams within a Tier have the same Ranking Score and the same Highest Match Score, then the Scoring System will sort those teams based on a random electronic coin toss.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 17-03-2005, 13:24
Rookie Year: 1997
Your UPDATE15 and MORELLA variables are reversed. (ie, checking update15 causes the morella method to be used).
Edit: I've checked the QP calculations for the update 15 method and they match mine and SOAP's.
Edit2: The Morella method looks good too.
Unread 17-03-2005, 16:09
AKA: Dr. Joe
FRC #0088 (TJ2)
Hopefully LAST version. 2005-03-17c
Hi all, I have made a new version.
It fixes the Morrella/Update15 mix up and adds the option to sort by highest QP or Highest Match Score.
I think it will work but who knows. Please test and let me know
Send me a short message on my pager: Reversed for my spamming protection
moc.liamriaym@6716584685
Here is the file.
Joe J.
Team #88, TJ2
Unread 17-03-2005, 17:05
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Hopefully LAST version. 2005-03-17c
Here is the file.
Joe J.
NOW MY PAGER SCREWS UP!!!!
I got a page from someone but it was too garbled to read.
If someone had feedback that I need to know, please post it here AND send a short note to my pager again. I will try to reply via my pager to confirm that I got it.
Thanks.
Joe J.
Team #88, TJ2
Unread 17-03-2005, 20:23
Update: The spreadsheet works in OpenOffice.org 2.0 Beta for those interested. The OFFSET thing was apparently a documented issue in how OOo 1.1.4 handled things and was fixed for 2.0
White Paper Discuss: Joystick Sensitivity Demystified - Version 2 marccenter Extra Discussion 0 28-02-2005 16:54
White Paper Discuss: Interrupts for Dummies CD47-Bot Extra Discussion 5 29-01-2005 03:24
White Paper Discuss: Omni-dirctonal Hoverbot CD47-Bot Extra Discussion 10 30-11-2004 00:32
White Paper Discuss: IndianaFIRST 2004-2005 Calendar CD47-Bot Extra Discussion 8 30-07-2004 20:26
White Paper Discuss: Controller Circuit- Infrared Emitters CD47-Bot Extra Discussion 1 13-02-2004 17:48
