Re: pic: 35 MPH Prototype
I calculated the theoretical top speed using the rpm and gear ratios in the transmissions. The big black tank is for the pneumatics to change gears. The tank is so big that we only filled it once for all the time we were playing with it. We didn't officially clock it at 35 MPH, but we were guestimating. And as for the caster in front, at the beginning it was centered. That thing bounced around so much I couldn't control it. But it was FUN!
The gear ratio in the transmission is 4.17:1 which is about 1247 rpm. Then it goes 1:1 from the transmission to the 12" wheel. Last edited by Crebb : 22-03-2005 at 15:00. |
The motor specs sheet I have been using has the CIM's going at 5200 rpm. That's what i've been basing my calculations on.
Whatever you do, don't show that design to Swampthing
. Next thing you know, they'll come up with a robot that goes 40+ miles/hour reliably. As if their robot wasn't fast enough... |
If your robot were traveling 35 MPH, it'd be able to cross a football field in six seconds. Can it? |
I admit that it isn't practical and we wont use this setup on our robot next year (most likely), but it sure is fun. |
Is it FIRST legal? I am assuming not because of the air tank you used.
This looks like something I would want to do in the summer in my free time. Yay for using math calculations to figure out speed
We used the long equations mentioned so we could gear our robot for ~12-15 Ft/S this season But heck, 35 MPH is insane. |
try a bigger battery, like 24 volts. That may change some stuff. Also you may want to impliment a cooling system if you haven't already.
#10
In 2004 for some reason someone thought 4:1 would be a good ratio to gear down the CIMs to the 12" skyway wheels. The bot moved all right, but it sounded angry. ugh... that thing was hard enough to control with a 13:1 gear down, I would have hated to try to drive it at 4:1... 2 side wheels, and a castor at each corner...
Very nice to see something as just proof of concept. ![]() Last edited by ConKbot of Doom : 31-03-2005 at 13:05. |
#11
Hey some of our team members decided it would be funny to put NOS stickers on our robot, so we have NOS. |
#12
Really James, don't let the resource officer find out about that,the speed limit on that road is 25 mph. You could get a ticket. Just think if you were given a speeding ticket for breaking the speed limit with a robot!
#13
Or use it to fuel a rocket engine! Just a matter of heating the stuff right. |
#14
| pic: Team 1595 Prototype!!! L@@K | sgsdragons | Robot Showcase | 18 | 10-02-2005 14:27 |
| pic: 1382 Brazil + Prototype Robot | tribotec_ca88 | Extra Discussion | 3 | 09-02-2005 13:49 |
| pic: Team 1382 Prototype LEGO Robot! | tribotec_ca88 | Extra Discussion | 7 | 19-01-2005 23:33 |
| pic: Swerve^2 Prototype | CD47-Bot | Robot Showcase | 24 | 23-01-2004 12:11 |
| pic: Team 857 Prototype Killough 2002 | CD47-Bot | Extra Discussion | 19 | 13-10-2003 08:12 |
