Go to Post The practical experience that students learn by working with the mentors on a real life problem -- with real life constraints -- helps produce people who are good at those professions. - MechEng83 [more]
Unread 22-03-2005, 15:47
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: pic: 35 MPH Prototype
Originally Posted by Crebb
The motor specs sheet I have been using has the CIM's going at 5200 rpm. That's what i've been basing my calculations on.
That is approximately the CIM motors free speed. The motors are operating under load, so the actual output RPM is going to be something far lower than that. Additionally, if you're using the FIRST provided circuit breakers, the motors will draw more than 40A under load at a speed considerably lower than 5200 RPM, were they ever to go that fast.
If your robot were traveling 35 MPH, it'd be able to cross a football field in six seconds. Can it?
--Madison--
...down at the Ozdust!
Unread 22-03-2005, 16:16
Crebb's Avatar
Crebb Crebb is offline
AKA: James M.
FRC #5279 (Bionic Eagles)
Crebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud ofCrebb has much to be proud of
We did have trouble tripping the breakers. The first time we tried it out we only had one CIM per gearbox, but we added two more. The road we tested on had a slight hill, so if we started off in first gear and shifted into second it did fine. As for the football field in 6 seconds, it would be close. I need to find a radar gun somewhere.
I admit that it isn't practical and we wont use this setup on our robot next year (most likely), but it sure is fun.
Shibuya Hoppmann, Mechanical Engineer
VCU School of Engineering 2012
Team 5279 2016-Present
Team 384 2003-2015
Unread 22-03-2005, 17:30
tkwetzel's Avatar
tkwetzel tkwetzel is offline
Good Luck Teams!
AKA: Tyler Wetzel
FRC #0116 (Epsilon Delta)
tkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond reputetkwetzel has a reputation beyond repute
Send a message via AIM to tkwetzel
Is it FIRST legal? I am assuming not because of the air tank you used.
Originally Posted by some young guy
o man i thought the black tank was for the Nirtous Oxide...darnet that would have been cool
Electric motors....nitrous oxide? They would get more power out of putting NOS stickers on their bot than actually putting a nitrous tank on it. Because all the NOS tank would do would be weigh down the bot .
See you in DC!
Unread 22-03-2005, 17:34
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
This looks like something I would want to do in the summer in my free time. Yay for using math calculations to figure out speed We used the long equations mentioned so we could gear our robot for ~12-15 Ft/S this season But heck, 35 MPH is insane.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 22-03-2005, 17:38
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
try a bigger battery, like 24 volts. That may change some stuff. Also you may want to impliment a cooling system if you haven't already.
Unread 31-03-2005, 13:00
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
In 2004 for some reason someone thought 4:1 would be a good ratio to gear down the CIMs to the 12" skyway wheels. The bot moved all right, but it sounded angry. ugh... that thing was hard enough to control with a 13:1 gear down, I would have hated to try to drive it at 4:1... 2 side wheels, and a castor at each corner...
Very nice to see something as just proof of concept.
2005 Philly #1 seeded team, highest average points, and semi-finalists
Thanks to 103 and 484 for being alliance mates.
Unread 22-03-2005, 18:30
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
Hey some of our team members decided it would be funny to put NOS stickers on our robot, so we have NOS.
our web site
Unread 22-03-2005, 19:12
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Really James, don't let the resource officer find out about that,the speed limit on that road is 25 mph. You could get a ticket. Just think if you were given a speeding ticket for breaking the speed limit with a robot!
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 22-03-2005, 20:17
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Or they could just open a large dump valve to spray the nitrous backwards, kinda like using a fire extinguisher to create propulsion, I mean, with a full tank, it'll be some high compression there.
Or use it to fuel a rocket engine! Just a matter of heating the stuff right.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 22-03-2005, 20:34
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
That would be cool, a 35mph bomb/rocket
Elknise
Issaquah Robotics
Unread 22-03-2005, 22:31
KTorak's Avatar
Fire Rescue 47
AKA: Kyle Dersch
Sounds Awesome, I want in on it!
Unread 22-03-2005, 22:52
24 Hours of LeMons?
I was wondering, how controllable is it at high speeds? How do you keep it driving straight, or do you just drive this in an open area? And most importantly, how fast does it accelerate from 0-35mph?
Unread 22-03-2005, 23:00
I have a Mabuchi RS 750SH motor (bigger than the FP but still maybe 1/2 size of CIM) sitting on my desk that I pulled out of an old Makita Drill. I was thinking I'd either build an RC car around it or put it in a car I have. How do you think I should gear that in a ~9lb car? How fast could I get it to go do you think?
Unread 23-03-2005, 07:14
Crebb's Avatar
AKA: James M.
It's hard to control when it starts bouncing around on the pavement. There's only one caster on the front and it fell off after a while. Acceleration is pretty good in first gear, but when I put it into second it takes a while to get the rpm's up.
We like to use that big pneumatics tank on prototypes because it lasts so long. It was just sitting around in the shop, so I wouldn't be suprised if it was from 2000.
Team 384 2003-2015
Unread 22-03-2005, 20:40
tkwetzel's Avatar
Good Luck Teams!
AKA: Tyler Wetzel
Cooling system? With it being as open as it is and running at 30+ MPH, I think they should get enough air flow to sufficiently cool everything.
See you in DC!
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
pic: 1382 Brazil + Prototype Robot tribotec_ca88 Extra Discussion 3 09-02-2005 13:49
pic: Team 1382 Prototype LEGO Robot! tribotec_ca88 Extra Discussion 7 19-01-2005 23:33
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
