pic: 35 MPH Prototype
Re: pic: 35 MPH Prototype
James! You know 6.5 isn't street legal! Bad robot! Bad! Let's hope our resource officer dosn't find out abou this....
How did you measure/calculate/verify the actual speed. Also, it must have been kind of scary with that caster wheel huh? Also, what is the big tank for?
Shifting without a compressor ?! (reason for tank maybe)
What was the output ratio from transmission output to wheel? |
I calculated the theoretical top speed using the rpm and gear ratios in the transmissions. The big black tank is for the pneumatics to change gears. The tank is so big that we only filled it once for all the time we were playing with it. We didn't officially clock it at 35 MPH, but we were guestimating. And as for the caster in front, at the beginning it was centered. That thing bounced around so much I couldn't control it. But it was FUN!
The gear ratio in the transmission is 4.17:1 which is about 1247 rpm. Then it goes 1:1 from the transmission to the 12" wheel. Last edited by Crebb : 03-22-2005 at 03:00 PM. |
The motor specs sheet I have been using has the CIM's going at 5200 rpm. That's what i've been basing my calculations on.
Whatever you do, don't show that design to Swampthing
. Next thing you know, they'll come up with a robot that goes 40+ miles/hour reliably. As if their robot wasn't fast enough... |
#10
If your robot were traveling 35 MPH, it'd be able to cross a football field in six seconds. Can it? |
#11
I admit that it isn't practical and we wont use this setup on our robot next year (most likely), but it sure is fun. |
#13
Is it FIRST legal? I am assuming not because of the air tank you used.
This looks like something I would want to do in the summer in my free time. Yay for using math calculations to figure out speed
We used the long equations mentioned so we could gear our robot for ~12-15 Ft/S this season But heck, 35 MPH is insane. |
#15
try a bigger battery, like 24 volts. That may change some stuff. Also you may want to impliment a cooling system if you haven't already.
| pic: Team 1595 Prototype!!! L@@K | sgsdragons | Robot Showcase | 18 | 02-10-2005 02:27 PM |
| pic: 1382 Brazil + Prototype Robot | tribotec_ca88 | Extra Discussion | 3 | 02-09-2005 01:49 PM |
| pic: Team 1382 Prototype LEGO Robot! | tribotec_ca88 | Extra Discussion | 7 | 01-19-2005 11:33 PM |
| pic: Swerve^2 Prototype | CD47-Bot | Robot Showcase | 24 | 01-23-2004 12:11 PM |
| pic: Team 857 Prototype Killough 2002 | CD47-Bot | Extra Discussion | 19 | 10-13-2003 08:12 AM |
