Go to Post This is a community that builds people as well as knowledge. - Karibou [more]
Unread 25-03-2005, 11:49
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: pic: Team 1341's 2005 Robot
Well, it wouldn't be stable if we had it that far up while driving. It's very stable when it's retracted though.
As for how we lift it, here's an image that might help describe it a little better:
We have a FP motor attached to a spool (link [the FP motor had a shield added after that picture]), which lead the whole aluminum arm up and down with two cords, one that would retract, and a second one that was looped around all of the steps on the arm (114ManualLabor was right). The cord was nylon (I think) with a 4-5mm diameter. The assembly was attached with gas shocks to the robot base and moved along a plastic tooth track by a Nippon-Denso motor. The drive train was a 6 wheel tank-drive (using inflatable 6-inch wheels at ~30psi), controlled by 4 CIM motors and the 2 standard FIRST-supplied gear boxes. On the bottom of the back and front we had two 1-inch hard rubber brakes that would stop us from tipping over.
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
