Go to Post At GLR our team only had to deal with a bunch on kids seeing snow for the first time. With all the ensuing snow fights and vainly trying to run up the giant snowy hill behind the arena. - Kevin Sevcik [more]
Unread 31-03-2005, 16:02
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: pic: 35 MPH Prototype
Originally Posted by M. Krass
That is approximately the CIM motors free speed. The motors are operating under load, so the actual output RPM is going to be something far lower than that. Additionally, if you're using the FIRST provided circuit breakers, the motors will draw more than 40A under load at a speed considerably lower than 5200 RPM, were they ever to go that fast.
If your robot were traveling 35 MPH, it'd be able to cross a football field in six seconds. Can it?
if you have efficient gearboxes the motor should be able to get fairly close to its rated freespeed.
it'll just take a while to get there, but the only resistive forces it would need to overcome would be innefficiency in the gearbox and wind resistance.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
pic: Team 1595 Prototype!!! L@@K sgsdragons Robot Showcase 18 10-02-2005 14:27
pic: 1382 Brazil + Prototype Robot tribotec_ca88 Extra Discussion 3 09-02-2005 13:49
pic: Team 1382 Prototype LEGO Robot! tribotec_ca88 Extra Discussion 7 19-01-2005 23:33
pic: Swerve^2 Prototype CD47-Bot Robot Showcase 24 23-01-2004 12:11
pic: Team 857 Prototype Killough 2002 CD47-Bot Extra Discussion 19 13-10-2003 08:12
