Go to Post Wisdom is knowing the difference between "the way to do things" and "the right way to do things." Just because an action may be physically possible does not mean that it is smart to do. - dlavery [more]
Unread 31-03-2005, 19:50
Towns1024's Avatar
Towns1024 Towns1024 is offline
AKA: Bill
FRC #2360 (P.O.W.E.R. Storm)
Towns1024 has a little shameless behaviour in the past
Send a message via AIM to Towns1024
pic: 5 batteries?!
Unread 31-03-2005, 19:52
Gentry Gentry is offline
Kil-a-Byte Support
AKA: Tom
#1024 (Kil-a-Bytes)
Gentry can only hope to improve
Re: pic: 5 batteries?!
In retrospect we should have used black wire.
Unread 31-03-2005, 19:59
Ahearn Ahearn is offline
#1024 (Kil-a-Bytes)
Team Role: Electrical
Ahearn has a little shameless behaviour in the past
Everyone knows green wire is the new thing. Where have you been?
Lasts forever, but takes forever to charge...
Unread 31-03-2005, 21:33
davelu davelu is offline
AKA: fffff
#0123 (fff)
davelu is infamous around these partsdavelu is infamous around these parts
Well, our team have tried with three batterys! and once we shortciruted a batter and the end of the battery connector melted. It scared that crap out of me and i was blind of a sec.... oh, ever tried this having 3 batterys red to red to red and black to black to black? ha i bet not cuz someone suggested that if you do it like that it is gonna be a parallel connection... ya, we did that and you can just imagine what happend afterwards
Unread 31-03-2005, 21:45
Kil-a-Byte Support
AKA: Tom
#1024 (Kil-a-Bytes)
Thats how we did our five, red to red to red to red to red and the same on black but as I learned dont touch the last red the same aluminum plate as the last black.......The more batteries the more possible current draw on a short..... Lots of sparks and small welding action. FUN. wait not so safe Oh well works great and lasts seemingly forever. Just take the last red and last black (or green in our case) and put them in a quick connect deal for the robot and works just like one super 12V battery that can supply in our case up to 5x more current
Unread 31-03-2005, 22:47
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
To clear up a few misconceptions...
Although one would think that connecting batteries this way should be possible, it is not. No battery has exactly the same terminal voltage as another battery, even fully charged batteries of the same type and manufacture. When two batteries are connected in parallel the slightly higher voltage battery will try to supply current to the lower voltage battery until it becomes the lower voltage and the the second battery will try to supply current to the first. Around and around the current goes until both batteries are dead and you haven't even connected it to anything yet. (It takes a while but it does happen)
Add a third battery and a fourth and the same thing occurs with more permutations.
The correct way to connect batteries (in parallel) for greater current is to use power diodes in series with the positive lead. If you can't stand the voltage drop of a power diode you can use a power Schottky diode which has a lower junction voltage. Connect the anode of each diode to the positive battery lead and then connect the cathodes of all the diodes in parallel.
As you have noticed, the more current capability the more dangerous shorts become. Have you ever seen a 1/4" open end wrench go incandescent?
For safety, the terminals of all batteries need to be insulated at all times and the output of the diode connection needs to be protected with a circuit breaker or fuse.
These batteries, even in single quantity, are capable of very high current, and if mishandled can result in fire, damage to battery and possible explosion hazard. It is essential to know the dangers of battery misuse. If you have a question just ask, I will get back to you.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 02-04-2005, 18:36
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
We used green to wire our operator interface. Not because it's better though, more because we didn't have any black wire. We also wrote in large paint pen letters on the back: "GREEN IS GROUND" to clear up any confusion that may result.
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 02-04-2005, 22:06
Kil-a-Byte Support
AKA: Tom
#1024 (Kil-a-Bytes)
Yeah we learned that our Lowes does not carry black 6 gauge wire. was either red or green
Batteries and hard impacts ConKbot of Doom Electrical 1 19-02-2005 13:39
Keeping batteries during shipping Andy Brockway Rules/Strategy 4 17-02-2005 17:37
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
Batteries Exide 2005 Quanity Mike Martus Electrical 6 13-01-2005 19:44
HELP - We have no batteries!! Rick Gibbs Championship Event 3 24-04-2002 19:07
