Re: White Paper Discuss: .NET Composite Dashboard Viewer
Has anyone tried using the ReplayRC view that is included with this application? It allows you to select a set of PWM outputs to record and generates a C source file to mimic motion captured while under human control. You just hit the capture button, drive around, and hit the stop button. The output is a C source file that you copy into your project and recompile. This has been done before so it wasn't a new idea.
Since the data packets are interlaced its only able to catch every third update of the PWMs. That means it probably will not match the driver's inputs exactly, but should be pretty close. The practice robot was in pieces tonight when I went to test so I'm curious whether anyone has used it and how well it worked. |
| White Paper Discuss: 2004 Visual Basic 6 Dashboard Control | CD47-Bot | Extra Discussion | 2 | 01-02-2005 01:56 |
| White Paper Discuss: 2004 .NET dashboard control dll | CD47-Bot | Extra Discussion | 7 | 13-01-2005 17:32 |
| White Paper Discuss: Comparison Paper for Teacher Involvement | CD47-Bot | Extra Discussion | 1 | 13-11-2004 00:09 |
| White Paper Discuss: Team 810's 2004 Dashboard Backend | CD47-Bot | Extra Discussion | 1 | 07-03-2004 10:32 |
| White Paper Discuss: VB .NET Dashreader custom control source | CD47-Bot | Extra Discussion | 2 | 19-01-2003 19:32 |
