Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 09-04-2005, 23:00
Rod's Avatar
Rod Rod is offline
Rod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to beholdRod is a splendid one to behold
Send a message via AIM to Rod
pic: One Tough Train
-Rod-
Team 662
Colorado Springs, CO
Unread 09-04-2005, 23:09
Re: pic: One Tough Train
Rod,
You don't come around these boards too often but when you do I am certainly impressed with your work. You are becoming a great robot designer. Have any of your designs been built? If so, I'd like to see some pictures.
A few notes:
-It might be better to mount the CIMs by the 10-32 threaded holes in their face rather than claming them on the can.
-Why use a coupling on the CIM shafts rather than just putting a gear?
-The transmission directly drives the wheel, I LOVE IT!
-The transmission has three plates, make sure there are never 3 bearings/bushings on a single shaft.
-For the sprockets, what size are they? I would recommend going the smalles you can (which would be 13T for #25 with 1/2" bore)
-Finally, have you considered a welded box tubing frame, they can come out to be very lightweight.
Last, I would like to offer you a picture of our frame in case you wanted to take any design cues from it. http://www.chiefdelphi.com/forums/pi...le&picid=10020 The pillow blocks slide for chain tension. Big tubing is 1.5x2 (probably should have used 1x2 and the small tubing is 1x1. All 1.8" wall.
Again, NICE WORK!
Unread 09-04-2005, 23:16
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
First of all ... very nicely done (inventor).
Few comments.
Very simple design, I like it. Looks like most of your weights are in the back of your chassis, I think you might want to look into that and make sure the chassis has central gravity. I can't really tell if your middle wheel of the chassis is lower than the other two according to this picture. If the middle wheel isnt lowered, you might want to do that for better turning. Did you think about making the chassis go a bit faster? You can always change the ratio (output transmission sprocket and the ones on the wheels). Looking at the top view... it looks like you sprockets are 1:1. What is the ratio of the transmission itself?
:: I heard them AndyMark Transmission is good::
Unread 09-04-2005, 23:36
Eugenia Gabrielov's Avatar
Eugenia Gabrielov Eugenia Gabrielov is offline
Counting Down to Kickoff
Eugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond reputeEugenia Gabrielov has a reputation beyond repute
I really like your design. I'd like to know what you plan to do with it, as mentioned before. The center of balance is towards one end, but it seems that if you put a manipulator closer to the empty end that wouldn't be a problem?
Hopefully all would balance out well. I also noticed it's riding pretty low. Are we anticipating another low necesity game?
And while I'm on it...how would the design, if used, be altered for a water game?
Northwestern University
McCormick School of Engineering 2010
Computer Science
Team 461 for life!
Unread 09-04-2005, 23:45
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: pic: One Tough Train
hey the 6 wheel drive looks awesome but you should put some chain in so that people can tell exactly how it works ar first glance. I like the wheels too and the idea is great.
2005 2006 2007 Autodesk Inventor Winner
2005 Winning Site & 2006 Winning Site
2007 Winning Site
Unread 10-04-2005, 00:02
SizzelChest330's Avatar
SizzelChest330 SizzelChest330 is offline
AKA: Elijah
FRC #0330 (Beachbot)
SizzelChest330 is just really niceSizzelChest330 is just really niceSizzelChest330 is just really niceSizzelChest330 is just really nice
Send a message via AIM to SizzelChest330
WOW..Impressive
...I take it there will be slight adjustments if the size limit changes next year...or if they have a "Platformish" thing again
but still...The weight is perfect for a strong base...trasmission is good!...and best of all...THOSE IS SOME TIGHT RIMS..hahah
Go Beachbot!
Unread 10-04-2005, 00:04
AKA: Ari
Maybe some doesnt know how to make chains in inventor (I have realized that it was very hard to make). One who has worked on a robot before would be able to look at that chassis drawing and would be able to tell where the chain goes. Now if it was a mechanism, then it's a totally different story. Team 103's (your team) inventor submission looks great this year. I saw that they used chains too on their robot. Mind sharing? Please tell us how to make the chains in Inventor. Thanks...
Rod.. I had another question for you...
I can't see how you mounted the Cim Motor on the transmission. Are they secured? Is it just two plates sandwiching those two motors together? Please explain or share a closeup picture? Thanks (if I am not mistaking, Rod has posted a picture of this transmission before the season started, just went through the image gallery, couldn't find it)
... The chassis looks great, would be nice to see it running around in reality.
Unread 10-04-2005, 00:31
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
That looks interesting....
Originally Posted by sanddrag
A few notes:
I mostly concur with sanddrag, except for that sprocket thing.
A couple of years ago, in 2003, Woburn used those same little sprockets, and promptly broke something like 13 #25 chains over the course of three events. Since there's no such thing as too much horsepower, the chain simply wasn't up to what we demanded of it. (It undergoes higher stresses as sprocket radius decreases.) You might consider looking at Tsubaki's General Catalog, Section 1, pages A-6 and A-7, where it gives power vs. speed vs. teeth-on-small-sprocket charts for #25 and #35 chains. (I'm always recommending this, it seems.)
Some quick calculations say that for your 5.5 in wheels at 6.5 ft/s, you need a wheel speed of 271 rpm. Plug that into the chart, and you get a rated power of 0.17 HP for #25. Two CIMs at 341 W each are good for about 0.91 HP, or 5.3 times your chain's rated capacity. (You're screwed ; that's even worse than Blizzard 4, in power-to-rating terms--it was an already-horrifying 5.1, even after accounting for its extra power!)
Of course, there's an answer: move up to #35, where the rated power for a 13 tooth sprocket (note that it's bigger than the #25 version, in all dimensions) is 0.94 HP, which is perfect.
I don't know how much of a safety factor chain manufacturers build into these ratings. I've got empirical evidence to demonstrate that it's not 5, however. Maybe 2, if you like to live dangerously--but gambling that the safety factor exceeds 5.3 really won't be pretty.
Unread 10-04-2005, 00:44
I'm not sure how or why you broke your chains but we ran a 6 motor 2 speed with #25 13T sprockets without a problem. While you are correct in saying you can easily exceed the working load, the breaking point is over 1000lbs. Also, it is not about the force the motors produce, it is about the force the wheels can hold on the floor. But yes, larger is safer.
Unread 10-04-2005, 01:02
I think a lot of it had to do with the style of play in 2003, versus this year. You mentioned elsewhere that your 2005 robot didn't have much pushing and shoving to do; by contrast, there were plenty of abrupt starts and stops in the 2003 game, not to mention outright collisions, where closing speeds could top 20 ft/s. Those represent shock loads not accounted-for in the 1050 lbf static breaking load (actually, for cheap #25 chain, it can be as low as 780 lbf, per the ANSI spec.). Add to this the fact that the three-motor transmissions would accelerate the robot very quickly, and reverse direction just as abruptly, and it's clear that the chains were doomed. But even with a much more relaxed driving style, and better chain tensioners than we had in 2003, 5.3 times the working load doesn't seem too safe.
Unread 10-04-2005, 01:06
Rod's Avatar
Rod Rod is offline
Rod,
A few notes:
Again, NICE WORK!
Thanks
A few answers
The gears used are a 55 tooth 3/8 face 20 DP for output and a 5 tooth stem pinion on the end of the Cim motor. The stem pinion has a 3/8" Dia. so it can not be mounted on the Cim shaft. That is why the Cims use a coupling and are not face mounted. I have put 3 bearings on a shaft many times and never had a problem. Our robot this year uses the same gearboxes and works perfect. The sprockets are 14 tooth #35 with 5/8" Bore. This year we had to add weight to our robot (17 Lbs.) We have a 55 Lb. drive train this year, that does not count the arm. So next year if we have a 68 Lb. drive train it should be about right. I read these boards every day, just don't post too much. Our designs have been built, they are posted here both the CAD drawings and this year's Robot. CAD drawings are titled Light weight drive train, we built a slightly modified version of it.
See Ya
-Rod-
Team 662
Unread 10-04-2005, 01:15
For 3 bearings on a shaft, it is a geometric overconstraint. Unless you can keep tolerances to under .001, you are losing efficiency.
Unread 10-04-2005, 01:35
Rod's Avatar
Rod Rod is offline
We use plain sleeve flanged bearings. The center bearing is bored out .020" over and is more of a gear spacer than a bearing.
Name:	06 Frame Assembly 4.jpg
-Rod-
Team 662
Unread 10-04-2005, 01:41
Ah, okay. So you really don't have 3 (close fitting) bearings on the shaft. Also, now I can see the need for couplings. Looks very small/compact!
I'm not sure if this would be a good idea but it seems like those couplings are taking up a lot of space in your otherwise compact design. If you got a gear just big enough to bore out and key to fit over the CIM shaft to keep the tooth count small (for 20P I believe this would be a 12T) then you could increase the 55 tooth gear just a little bit (maybe to 60) or maybe even keep it that size for a faster robot then you could move the CIMs in closer and mount them by the face to that first red plate.
Unread 10-04-2005, 01:47
Rod's Avatar
Rod Rod is offline
We are at 11:1 now. If we used 12T to a 60T we would be at 5:1> That would be way to fast for us with no low end.
-Rod-
Team 662
pic: Team 11 Drive Train Team S.Nickens Robot Showcase 2 22-02-2005 02:13
pic: Next Years Drive Train CD47-Bot Extra Discussion 15 11-06-2003 21:32
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
