Go to Post This is just one example of why you MUST NOT make engineering decisions based on assumptions. You should check/measure your parts and make appropriate design adjustments. - Stu Bloom [more]
Unread 14-04-2005, 17:01
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: pic: Just was not enough room
Originally Posted by AmyPrib
Now - this situation has been discussed before... Should this be counting? Q/A came out saying that a tetra was not part of the robot, except for in the HP loading zone.
So - is there any official FIRST ruling about a "supporting" object here? Technically - it's not touching carpet outside the line, so according to the rules, it should count?
Since this also just came up in two different PMs, I throw in my $0.02
Regarding the "bonus points" question, the refs made the correct call by not awarding the "end zone" bonus. The more complete explanation by FIRST of the "when is a tetra part of the robot?" answer does not change this situation. Rule <C03> says that "all three ROBOTS of the same alliance in their designated END ZONE at the conclusion of a match is worth 10 points to the alliance. A ROBOT is not considered in the END ZONE if it is touching the field outside the defined ENDZONE border." Notice is says touching the field - not "touching the carpet" outside the border. I would posit that for this purpose a tetra sitting on the carpet is considered part of the field. And in this case the tetra is clearly outside the end zone tape border. So the robot is touching the "field" outside the border. Therefore, the robot is not within the end zone as defined in Section 4.2.1, so it does not satisfy the criteria for the bonus points, so no bonus.
-dave
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
pic: 2005 Team 1549 Rookie Pic Eupher Robot Showcase 7 01-03-2005 11:20
pic: WBI-461 Rowdy Pete 6 Pic #2 Josh Hambright Robot Showcase 10 27-02-2005 02:10
pic: Local Paper shot pic at Robot "Bon Voyage" send off falconmaster Extra Discussion 1 26-02-2005 10:34
