Go to Post The phrase "Gracious Professionalism" is being thrown around much too often to try to support anything and everything that a certain individual feels is unjust. - Neo3One3 [more]
Unread 14-04-2005, 18:39
AmyPrib's Avatar
AmyPrib AmyPrib is offline
AmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond reputeAmyPrib has a reputation beyond repute
Re: pic: Just was not enough room
Originally Posted by dlavery
Since this also just came up in two different PMs, I throw in my $0.02
Regarding the "bonus points" question, the refs made the correct call by not awarding the "end zone" bonus. The more complete explanation by FIRST of the "when is a tetra part of the robot?" answer does not change this situation. Rule <C03> says that "all three ROBOTS of the same alliance in their designated END ZONE at the conclusion of a match is worth 10 points to the alliance. A ROBOT is not considered in the END ZONE if it is touching the field outside the defined ENDZONE border." Notice is says touching the field - not "touching the carpet" outside the border. I would posit that for this purpose a tetra sitting on the carpet is considered part of the field. And in this case the tetra is clearly outside the end zone tape border. So the robot is touching the "field" outside the border. Therefore, the robot is not within the end zone as defined in Section 4.2.1, so it does not satisfy the criteria for the bonus points, so no bonus.
-dave
This is a good point, and the tetra is now an extension of the field.. This does make good sense. Seems like it was defined somewhere as not touching the carpet outside the line, but we see the rule as written.
Plus, I found
ID: 1200 Section: 4.3.1 Status: Answered Date Answered: 1/17/2005
Q: If a robot of a single team is disqualified and disabled by a referee during a match, must its alliance members push the now dq'd bot into the endzone to get the 10 pt bonus at the end of the match?
A: The only way to score the 10 points is to have all robots touching only inside the end zone
.. which basically says you can't be touching anything outside the defined endzone border, but that should not (does not, I believe) include a tetra that was pushed into you as you mind your own business sitting completely within the zone.
Co-Chair Boilermaker Regional Planning Committee 2004-2011
2008 St. Louis Regional Finalists and Engineering Inspiration Award
2007 St. Louis Regional Champions - Thanks 1444 & 829! / St. Louis and Boilermaker Quality Award
2006 Boilermaker Chairman's Award
Referee - IRI - 2005, 2006, 2007, 2008
2005 Midwest Regional - Semifinalist, Engineering Inspiration Award, and Safety Award / Boilermaker Regional - Judges Award
2004 Midwest Regional Champions - Thanks 269 and 930! / IRI Runner-Up - Thanks to 234 and 447!!!
2004 Championship: Archimedes Finalist - Thanks 716 and 1272!
"We are going to be praised and criticized more than we deserve. We are not to be affected by either." ~ co-worker
pic: Team 759 CAD pic (almost finished) oljomo Extra Discussion 6 01-03-2005 16:31
pic: 2005 Team 1549 Rookie Pic Eupher Robot Showcase 7 01-03-2005 11:20
pic: WBI-461 Rowdy Pete 6 Pic #2 Josh Hambright Robot Showcase 10 27-02-2005 02:10
pic: Local Paper shot pic at Robot "Bon Voyage" send off falconmaster Extra Discussion 1 26-02-2005 10:34
