Go to Post Sooo....in the famous words of Douglas Adams, Don't Panic. - Conor Ryan [more]
Unread 09-05-2005, 20:34
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: pic: Jester Drive:Mecanum Wheel Drive Train
Originally Posted by ConKbot of Doom
When I first saw 357 strafe, I was driving in a match in Philly, and I don't know if they were on our alliance or the other, but I was amazed. Especially since how it worked wasn't immediately visible. I had a look later, and loved what I saw. Very nice job guys.
As for control's why not go for a keyboard and a joystick? make the keyboard be WASD, for strafing and forwards/backwards, and joystick for turning. A mouse would be even cooler, but a bit harder to implement. Would be neat to see...
I mean it works for First person shooter's, why not a robot
A keyboard limits you a lot - allowing you to only move in 4 directions rather than an infinite amount that the joystick allows you. A mouse doesn't really give you anything that a joystick doesn't, and you have to worry about running out of room on the mousing surface. We (190) use a joystick for the direction vector (relative to the driver) and a 2nd joystick for rotating counter clockwise or clockwise. We're probably going to set it up with a single 3 axis joystick to make it more intuitive, however. The second joystick also has the issue with more experienced drivers, when they start driving it tank-drive style.
pic: Tribotec Brazil - Drive Train tribotec_ca88 Robot Showcase 5 07-02-2005 03:48
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
