Go to Post It's 9:00 Do you know where your bott is? - Michelle Celio [more]
Unread 10-05-2005, 20:01
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: pic: Jester Drive:Mecanum Wheel Drive Train
Originally Posted by Alex357
Controlling an omni wheel is much different than controlling a mecanum wheel. Since the rollers are perpendicular on omni-wheels, the direction produced has almost no similarities with controlling mecanum wheel motion, which depends on the rotation and speed of each individual wheel.
Omni wheels all 45 degrees apart from each other produce exactly the same effect the mecanum wheels do, and you can control the robot exactly the same way. This is how we prototyped the code for our field relative drive and found that we needed to have the split in the chassis to have equal wheel pressure.
pic: Tribotec Brazil - Drive Train tribotec_ca88 Robot Showcase 5 07-02-2005 03:48
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
