Go to Post What's the point of competing if you're not going to be competitive? - davepowers [more]
Unread 10-05-2005, 22:51
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: pic: Jester Drive:Mecanum Wheel Drive Train
Originally Posted by Alex357
Controlling an omni wheel is much different than controlling a mecanum wheel. Since the rollers are perpendicular on omni-wheels, the direction produced has almost no similarities with controlling mecanum wheel motion, which depends on the rotation and speed of each individual wheel.
As BrianBSL said, its exactly the same. Mechanum wheels have rollers at 45 degree angles, for the omni holonomic drove you put the entire wheel at 45 degrees. There are slight differences but its still the same.
Originally Posted by BrianBSD
This is how we prototyped the code for our field relative drive and found that we needed to have the split in the chassis to have equal wheel pressure.
We shimed our wheels so that all the wheels are touchign at the same time. Also we have encoders on everywheel to track how fast each wheel goes. We had a suspension of sorts on our mini bot we prototyped on last year and found it wasnt super important since the field is relatively flat.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
pic: Tribotec Brazil - Drive Train tribotec_ca88 Robot Showcase 5 07-02-2005 03:48
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
