Re: pic: Omniwheel version 2.1
When it is so boring and slow on here in the summer it is funny how all of us just jump at something technical. I don't quite recall exactly what polyurethane is like (the only thing that comes to mind at the moment is the liqid stuff in a can that I applied to the top of my workbench to seal it) but are you sure it is going to spin well on the steel pins? Perhaps you would consider pressing a brass tube into the roller to let that ride on the pin. Also, there must be some sort of provision so the end of each roller doesn't rub on the plates.
Anyway, this wheel design isn't really that different from most I've seen, but it sure is welcome in these barren forums around this time of year. ![]() |
Well Materials isn't my strong suit, I selected that based on recommendations from my sister, so...I honestly couldn't tell you, but she claims it should work, good enough for me.
This is a good design. It needs some improvements, but it not too many.
1. Urethane rollers are good. Wildstang uses that materials in their "bupods". I am not sure what durometer to use, but try 50a (soft), 60a, or 70a (harder). 2. The gap between the rollers and the aluminum plates does not need to be as much as you show. I suggest a 0.02" gap on either side of the roller at the most. 3. The pockets for the rollers need an inner radius, if you are going to machine this with a CNC mill. A 1/8" or 3/16" radius will work fine. When you make this inner radius, you may need to make the pocket deeper so that the roller still clears the aluminum (that was a problem in the early versions of the 6" AndyMark trick wheel this past year). Also, the outer corner needs a small radius, in order to not dig into the urethane roller. 4. 5 screws holding the two plates together is a low number. You really don't know what kinds of loads this thing will see... it will get banged from the side, and it will see many dynamic loads. I suggest doubling the number of screws and moving them out, away from the center. Also, if you use an even number of screws, you can fasten them without nuts by having every other hole be a tapped hole. 5. The bore either is designed for a driven shaft (keyway, trantorque, etc.) or a bearing (driven by a sprocket). If it is a keyed shaft, the keyway in those two plates will get stripped. If you want to drive this with a shaft your keyway will need more face width. You can do that by adding a bolted-on hub. If it is driven by a sprocket, that can be bolted on in the same manner. This is the start of a good design, Matt. I like the simplicity of two plates. Also, I applaud your courage for posting this (and other) design. Keep up the good work! Andy B. |
| Linux and new microcontollers. | djcapelis | Programming | 48 | 29-01-2005 00:26 |
| pic: Version 1.1 | Arefin Bari | Extra Discussion | 24 | 01-12-2004 21:58 |
| Tecnho/Remixed Version of Pomp & Circumstance | Yan Wang | Chit-Chat | 0 | 23-06-2004 12:40 |
| PBASIC Editor V 2.0 Beta 2.1 available | Lloyd Burns | Programming | 0 | 08-07-2003 07:25 |
| Q&A Watcher Available for Download | Nate Smith | General Forum | 11 | 19-12-2002 11:12 |
