Go to Post There's no crying in robotics! - TubaMorg [more]
Unread 23-06-2005, 13:04
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Re: pic: Planetary...Wheel?
Originally Posted by Andy Brockway
Matt,
Is the ring gear attached to the wheel? If so, what forces the wheel to turn? Most planetaries will allow the moons to spin around the sun when the outer ring is stationary.
I suppose this will be cleared up when you post the exploded view. I believe you want the moons attached to the wheel with the outer ring fixed to the frame.
As I understand it, having seen the exploded view, the sun gear is on the motor output, the planets are stationary, and the ring gear is locked to the wheel. If I'm not mistaken, this setup will cause the ring gear to spin in the opposite direction as the motor, with a reduction equal to the number of teeth on the ring, divided by the number of teeth on the sun gear. Is this correct?
Over all, I was pretty impressed with this design. Matt showed it to me a few weeks ago, and I was considering using it in a summer project, though I ended up going in a slightly different direction. It seemed to me like a pretty easy, compact way to do a direct-drive gear reduction.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: "Omni Grenade" Wheel D.Fahringer Extra Discussion 20 11-12-2004 13:02
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
