Go to Post You've got to love the great connection between FIRST teams, and their members. - zakk [more]
Unread 23-06-2005, 22:15
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: pic: Planetary...Wheel?
I'm not an expert on gears by any means, but I think just spreading the load across the gears won't help that much. Gears are meant to operated at fixed distances on fixed shafts. 25 pounds of force pushing the gears into each other isn't going to make them happy. Even if you could get it down to 5 pounds, you'd still lose a lot of efficiency. I think your best bet is to figure some way to get a bearing supporting the wheel so you're not using the gears as a bearing sort of surface. This would help with the side loads too.
I'm thinking a big thin section ball bearing that goes around your array of bearings there and slips inside a rim on the wheel. At that diameter a brass bushing might work as well.
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: "Omni Grenade" Wheel D.Fahringer Extra Discussion 20 11-12-2004 13:02
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
