Go to Post Bottom line is I love FIRST and what it stand for. Hold nationals in a corn field on old crates and I'll support it! If the FIRST staff is reading, Thank you for all the hard work you do! - Gene F [more]
Unread 24-06-2005, 00:57
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Rookie Year: 1997
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Re: pic: Planetary...Wheel?
Hey nice design. One way to reduce the range of loading on the gears would be to find a way to support the wheel on it's own bearing. It may have to be a needle roller bearing with a large inner diameter to keep the design compact but it should work out with a bit more structure. That way the wheel loads go to the bearing and the gears don't have large time varying loads that will occur even without impact with the present design.
Also, you can get away with using fewer gears now that the loads don't have to be distributed that much. That should save a little on weight.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: "Omni Grenade" Wheel D.Fahringer Extra Discussion 20 11-12-2004 13:02
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
