Go to Post I need a This-Is-What-I-Meant checker. - N7UJJ [more]
Unread 26-06-2005, 23:48
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
Re: pic: 3 speed concept - 1st gear
What are you planning to shift with? Pneumatics or another method?
Also, are you going to do anything to make sure that the gears mesh right away - make sure shaft 1 and shaft 2 rotate at the same speed, round off the teeth a bit (given that the gear is thick enough to do so), etc.?
One more question (probably with obvious answer, but I'm sleepy ), the middle shaft isn't just going to be hanging like that in first gear, right? It's going to be extended through the plate?
Anyway, looks cool, I like.
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: Need an EDU Beval Gear CD47-Bot Robot Showcase 8 30-10-2003 14:03
