Go to Post Nascar was one of the first things i though when the unveiled this years competitions...... silly left turns... they hurt right turns feelings :rolleyes: - Miniflash [more]
Unread 27-06-2005, 00:33
Re: pic: 3 speed concept - 1st gear
The shaft would be exntended, no hanging in mid air.
I don't actually plan to build this thing, but if I did here's a few things I would do.
Actuation: Not really sure but I'm thinking pneumatics for speed and strength. Might try multipositioning but maybe just use two cylinders in series.
Gears: Might try 3/8" wide to save space, but 1/2" is probably a safer bet. 20 pitch seems to work well and be readily available. I suppose beveling the edges a little bit would aid in meshing, probably adding a couple thousandths in the c-c distance would as well. Other than that, I wouldn't match speeds or anything, it should be fine
Any more comments/ideas?
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: Need an EDU Beval Gear CD47-Bot Robot Showcase 8 30-10-2003 14:03
