Go to Post FIRST needs a disclaimer that parts of the field can become flying projectiles under hurricane force winds. - Barry Bonzack [more]
Unread 27-06-2005, 11:37
Re: pic: 3 speed concept - 1st gear
Originally Posted by Kevin Sevcik
57 uses a tranny like this but with just 2 gears.
Actually rounding or beveling the sides of each tooth helps the most and hurts your tooth face width the least. Of course it requires a good hand with a dremel and a lot of patience.
Lots of teams use a tranny like this with only two gears. That's where I got the idea. But my idea was to expand it to make it a 3 speed.
As for beveling the teeth, why would you dremel each one as opposed to chucking it up in a lathe and filing it or even making a light cut?
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
pic: Need an EDU Beval Gear CD47-Bot Robot Showcase 8 30-10-2003 14:03
