Go to Post In my book the team building experience of the kids training the engineers in the operations on the field would be invaluable. It might not get a trophy but you win far more in the long run. - Wayne C. [more]
Unread 27-06-2005, 16:05
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Rookie Year: 1997
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Re: pic: Planetary...Wheel?
I think the internal gear idea can work if the pitch diameter is large enough. Then it wouldnt require nearly as much force on the gear teeth as it would be applied far from the center of rotation. This thread actually made me resurrect an old idea that can possibly make a very compact drive module. The gears(except the internal gear), brackets and shafts are missing from the inventor drawing, but the spacing has been worked out in 2D. The model so far should give you an idea of what I'm working towards though. The gear ratio ends up being about 15:1. The weight looks like it will end up being about 8 lbs and the size is about 8"x6"x6". The design obviously needs more thought, but I figured that I'd put it out there.
I have many variations of this design that move components around for different purposes. This one is to minimize the amount of gearing and space for the motor-gearbox-wheel system.
Jevawn
BTW i did this last night at around 4:30am so any resulting crappyness of the model can be attributed to that.
Name:	compact internal wheel.jpg
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Wheel got dented during a match davelu Robot Showcase 24 05-04-2005 23:58
pic: "Omni Grenade" Wheel D.Fahringer Extra Discussion 20 11-12-2004 13:02
pic: Planetary Gearset CD47-Bot Robot Showcase 3 22-12-2003 01:55
