#30
Re: pic: Robo-one legs
If I remember your past post about the atom, there was a problem with your use of the servo command. Look at the docs on the servo command.
Servo 1,5 will repeat this command 30 times by default which takes about 1 second to execute. Try servo 1,5,1 This will take about 30 ms to execute. To control that many servos you going to need a servo board. Most servo boards are serial or I2C controlled. Serial is probable easier, I2c is most likely faster. |
| Programming a 2nd PIC | ImmortalAres | Programming | 8 | 16-06-2005 12:13 |
| Learning PIC C | Adam Collet | Programming | 18 | 19-10-2003 19:36 |
| PIC Programmers | seanwitte | Electrical | 8 | 18-04-2003 17:04 |
| pic: Team 522 Robo Wizards Mckee H.S. Staten Island N.Y. | CD47-Bot | Robot Showcase | 18 | 17-04-2003 20:40 |
