Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 02-08-2005, 07:08
Gdeaver Gdeaver is offline
FRC #1640
Re: pic: Demo Transmission 222
Some small timing belt super glued to the circumference of the polycarb would allow a fairly functional gear. No machining required.
Unread 04-08-2005, 03:38
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
The belt idea would probably work, however you would still have to machine something down to accommodate for the thickness of the belt.
I would not use the timing belt as a gear, I would just use the belt for traction. The main I idea of this to keep the shifting part of the transmission clear, so attaching one belt to each of the other "wheels" besides the shifting "wheels" would probably give enough traction.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
pic: Tigertrons 222 05 Pic #2 team222badbrad Robot Showcase 4 01-03-2005 08:25
pic: Team 30 Dual-Motor Transmission CD47-Bot Robot Showcase 27 10-02-2004 18:35
pic: TechnoKat Transmission 2003 CD47-Bot Robot Showcase 55 23-07-2003 14:41
pic: Demo Girls! CD47-Bot Extra Discussion 2 14-04-2003 11:21
