Go to Post I knew that the students on our team really understood what FIRST was all about when, two years later, our unofficial team motto changed from "we want to BEAT Chief Delphi" to "we want to BE Chief Delphi." - dlavery [more]
Unread 04-08-2005, 15:18
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
pic: Rustler
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Unread 04-08-2005, 15:19
[527]phil's Avatar
Alumni
AKA: Phil
Re: pic: Rustler
10 points to whoever can guess the kind of drumset thats in the background.
Unread 04-08-2005, 15:20
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
Re: pic: Rustler
a Remo Drum set?
Unread 04-08-2005, 15:41
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Ryan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud ofRyan M. has much to be proud of
Re: pic: Rustler
Originally Posted by Arefin Bari
a Remo Drum set?
That's my guess... I guess.
Unread 04-08-2005, 16:43
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Re: pic: Rustler
Remo typically makes drum heads, so I'll go with Yamaha. They make a lot of drums.
Unread 04-08-2005, 18:20
[527]phil's Avatar
Alumni
AKA: Phil
Re: pic: Rustler
Lol, nope it's not remo or yamaha.
Unread 05-08-2005, 00:46
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: pic: Rustler
Don't use cotter pins. Use a paper clip, and wrap it through the posts and around a few times. If they come off, eh.. much easier to replace - and cheaper.
Plus a paper clip is so pliable that you can put them on and take them off no problem.
Unread 05-08-2005, 01:06
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: pic: Rustler
If I'm not mistaken, it's a Pulse Pro 5-Piece Lacquer Drum Set.
linky
Unread 05-08-2005, 01:12
Re: pic: Rustler
Are you talking about the clips that hold the body on? If so, those aren't cotter pins. They are hitch pin clips. I've popped them off only very few occassions. If they pop off too easily, you can get stiffer ones. The traxxas ones are probably the weakes I've seen. Go to your local hardware store (not Home Depot, anywhere else should have them) and you get get some stiffer ones. They aren't too expensive. Paper clips can only bend back and forth a few times before they break, and I think it would be ugly.
Unread 05-08-2005, 09:14
[527]phil's Avatar
Alumni
AKA: Phil
Re: pic: Rustler
I'm pretty sure their cotter pins, but I have gone to the hobby store and I bought alot more. And the answer to the drum set question is.... mapex. yup 5 piece mapex pro M series in cherry red .
Unread 05-08-2005, 14:54
Re: pic: Rustler
Cotter pin
Hitch pin clip
And if you don't believe me, here they are in the package.
So, go to your hardware store and buy some more "hitch pin clips" that are made of thicker wire. If need be, you can also drill out te body mount holes a little bit for a little bit thicker wire clip
Linux and new microcontollers. djcapelis Programming 48 29-01-2005 00:26
Learning PIC C Adam Collet Programming 18 19-10-2003 19:36
PIC Programmers seanwitte Electrical 8 18-04-2003 17:04
Who am I pic... Pamela CD Forum Support 6 23-07-2001 23:49
