Go to Post Andy Baker's breakfast of choice is Kellog's Nuts and Bolts. - Adam Y. [more]
Unread 15-08-2005, 17:41
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: pic: Team Fusion's T-Shirt Shooting Robot
What are you using as the valve? SCH40 PVC is good up to it's pressure rating, which should be printed on the tubes, and I think it's far past 250 psi. The PVC joints are always built stronger than the pvc piping, so as long as you cured/glued the joints correctly, all will be fine.
I always like to put my psi limit depending on the valve, I usually use a normal sprinkler valve, which is good to 120 psi; so I set mine to 100-110 psi and it can shoot stuff far enough for my purposes. If you're using a ball valve, you could go higher, but at that point I'd be scared, lol. I suppose you could make some type of scatter shield for it.
If you're having problems shooting the t-shirt high up into the stands, try cramming the shirt down the barrel, hard. You don't want any air bleeding past the t-shirt.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
