Go to Post Dreams come and go, but once life throws a football you have to think fast. - Pavan Dave [more]
Unread 15-08-2005, 18:04
bhweezer's Avatar
bhweezer bhweezer is offline
Brandon Higgs
FRC #0364 (Team Fusion)
bhweezer is a jewel in the roughbhweezer is a jewel in the roughbhweezer is a jewel in the rough
Send a message via AIM to bhweezer
Re: pic: Team Fusion's T-Shirt Shooting Robot
Originally Posted by NoodleKnight
What are you using as the valve? SCH40 PVC is good up to it's pressure rating, which should be printed on the tubes, and I think it's far past 250 psi. The PVC joints are always built stronger than the pvc piping, so as long as you cured/glued the joints correctly, all will be fine.
I always like to put my psi limit depending on the valve, I usually use a normal sprinkler valve, which is good to 120 psi; so I set mine to 100-110 psi and it can shoot stuff far enough for my purposes. If you're using a ball valve, you could go higher, but at that point I'd be scared, lol. I suppose you could make some type of scatter shield for it.
If you're having problems shooting the t-shirt high up into the stands, try cramming the shirt down the barrel, hard. You don't want any air bleeding past the t-shirt.
We don't have any problems with getting distance with the shirts. When I shot them I had two different ways of folding the shirt. One would go maybe 10 yards, the other could easily go 40 yards. A couple of times we shot shirts over crowd and into the parking lot. I'll make sure to get some pictures of the cannon in action after the first football game in a couple of weeks.
The valve is a RainBird in-line irrigation valve. It's only $16 at Lowe's.
Team Fusion (364)
Synergy in Motion
pic: Team 114 Real Robot Vs. Inventor Robot James114 Robot Showcase 3 18-02-2005 13:02
pic: team 909's robot - pic 2 Brad Lanpher Robot Showcase 8 16-02-2005 08:34
First Year Team Assistance - MOEmentum: FYI Mr MOE General Forum 0 07-01-2005 14:07
How Many FIRST shirts do you own? Joe Ross General Forum 81 31-08-2004 10:36
Best Robot Ever(again) Corey Balint General Forum 26 04-08-2004 23:03
