Go to Post FRC is about what we collectively make of it. - Tristan Lall [more]
Unread 15-08-2005, 18:46
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
Re: pic: 2 speed dogshifter
Originally Posted by Karthik
EDIT: Hognabbit, John beat me too it...
It's because I used a spreadsheet.
Unread 15-08-2005, 19:26
Well, I'm glad that is sorted out. All our numbers were in agreement but we didn't even know it. What threw me off is (1) when I asked for speed at the gearbox and got speed at the wheel (no biggie) and (2) the 81% number that everyone seemed to know about except me.
Anyway, for the dog, I never meant to imply that all shifting dogs should look like the one 696 made. Heck, we modeled ours after 45 and 968. However, if you are going to do it 45/968/696/etc style (three "fingered" dog) I would suggest keeping it that way and not staggering the dogs fingers on the opposing side.
But yes there are some other ways to do shifting dogs (that don't require CNC) like team 716 style square and pin and hole.
For the size of the shifting dog, what you have looks fine. For the travel, we left a .020 neutral space in ours which worked perfectly. More or less, we made the dog .020 less wide than the space between the dog gears. This allowed enough room to be clear of any potential double engagement (disaster! if it were to happen) but it was small enough that as soon as you were out of one gear you were into the next as soon as the dog fingers aligned with the pockets int he gears. No time wasted in neutral.
Our dog had just under 1/4" of engagement into the gears and worked on 1/2" stroke. We could have probably gotten away with much less but we didn't want to take any chances since it was in the last stage of reduction and behind the power of 3 motors in each box. Teams like 968 run their dogs with about 1/8" of engagement and about .25" of stroke.
In this dog setup you will get a lot of backlash due to the nature of the design. You want the dog pockets in the gears to be wider than the dog fingers on the dog.
We made our dog fingers a straight and easy 60 degrees. We made the pockets only 64 degrees to minimize backlash. It worked well but I wouldn't go with any less than that. You might risk missing a shift if you go smaller than 4 degree difference between the fingers and the pockets. We shifted on about 45 psi usually. A full 60 might have given a faster shift, but we didn't want to apply more side loads than necessary. You might get a little bit quicker shift on maybe a little bit less pressure if you open up the pockets in the gears to 66 degrees but you will get extra backlash.
When drawing your gear pockets and dog pockets/fingers (depending on if you added or removed during extrude) make sure that the lines point to the center of the piece, not just a point on the hex (for the dog). With hours, this was discovered just moments before machining and had to be corrected. You want the lines pointing to the center so you get a flat face-on-face engagement.
Also, I just want to confirm that you do have the dog gears spinning on something. I'm interested in your plans, because everyone does it a little bit different way.
Finally, I think the box can made to be smaller, maybe using smaller gears. I would see what is the minimum gear size you can put between the Chias without having them run into each other. For high gear, it wouldn't make any difference since that initial mating 60 tooth gear has no effect on the high gear speed. For low gear, you'll just want to play with it a bit until you get what you want. That may be a little tricky. I'll think about this some more.
Feel free to use any layout, gear sizes, ratios, etc from this pic www.team696.org/hexamax_ratios.jpg to help with your design if you'd like. (Note: In that pic, it is not mentioned that the FP is the 6V model running at 12V and fed through an AM planetary. The 14T gear is on the AM planetary.)
EDIT: Also 4:1 difference between high and low seems like a pretty large jump to me. For the speeds (in fps) you mentioned I think you may find yourself wanting something with more torque than high gear but more speed than low gear when you're on the field. I guess it all depends on the game, but I just wanted to let you know the ratios can be tightened up a bit if desired, something more along the lines of 2.5:1 - 3:1 between high and low.
Unread 15-08-2005, 21:10
nehalita's Avatar
nehalita nehalita is offline
Robots are friends
AKA: tagger fanatic
FRC #1345 (Platinum Dragons); FRC# 97 (RoboRuminants)
nehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond reputenehalita has a reputation beyond repute
Send a message via AIM to nehalita Send a message via MSN to nehalita Send a message via Yahoo to nehalita
Being no expertise in this sort of field (==true) -- or a person of ANY experience,
this looks great. i had fin explain it to me (in elementary terms) and it's really amazing what this thing can do!
Looks like the talent speaks for itself (and the talent behind the talent)
"Relativity applies to physics, not ethics." Thank you Einstein
MIT '10
Proud Member of H.I.L.
The PLATINUM DRAGONS are on FIRE!
Unread 16-08-2005, 08:39
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Arefin...nice work on the design. I only have one suggestion, the 4:1 ratio seems a little wide for real smooth shift on the fly action. 222's transmission this year had a 3:1 ratio between first and second gear and with a single CIM it was too wide of a ratio. I know with a second CIM on the trannies we wouldn't have noticed as much lag in acceleration. That's just my $.02 nice work on the design though and look forward to seeing it on a machine in 06.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
