Go to Post remember to keep this simple but yet complex everyone - Team#2057-Vegas [more]
Unread 16-08-2005, 22:04
Holtzman's Avatar
Holtzman Holtzman is offline
Sometimes...
AKA: Tyler Holtzman
FRC #2056 (OP Robotics)
Holtzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond reputeHoltzman has a reputation beyond repute
Send a message via MSN to Holtzman
pic: 4 Wheel Strafing Chassis
"making the simple complicated is commonplace; making the complicated simple, awesomely simple, that's creativity." - Charles Mingus
Unread 16-08-2005, 22:31
Holtzman's Avatar
Sometimes...
AKA: Tyler Holtzman
Re: pic: 4 Wheel Strafing Chassis
As promised, here are the zip files with additional jpegs. They needed to be shrunk to make the file size limitations.
PM me if you want any closeups.
Unread 16-08-2005, 22:35
Looks good. I'm just curious, why did you go with sprockets as opposed to gears?
Unread 16-08-2005, 22:42
bhweezer's Avatar
bhweezer bhweezer is offline
Brandon Higgs
FRC #0364 (Team Fusion)
bhweezer is a jewel in the roughbhweezer is a jewel in the roughbhweezer is a jewel in the rough
Send a message via AIM to bhweezer
Looks great! One quick question though. Do all four wheels turn or only the wheels on the side of the steering assembly?
Team Fusion (364)
Synergy in Motion
Unread 16-08-2005, 22:50
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
And to amend to that question, why was that decided upon?
Unread 16-08-2005, 23:02
Holtzman's Avatar
Sometimes...
AKA: Tyler Holtzman
I choose sprockets were used for a couple reasons. There was quite a debate among team members regarding this. I am not the head designer for my team. This was something I worked on my own. It was my opinion that sprockets were the way to go for these reasons:
1. cheaper
2. allows for more flexibility for choosing distances while maintaining gear ratio's
3. requires less precision in holding tolerances when machining side plates.
4. Allows for a change of gear ratio's easily.
5. just as efficient as gears if chain is correctly tensioned.
(I calculated the center distances with Matt Adams sprocket center distance calculator. Thanks Matt)
All 4 wheels turn together, and steering is tank style. Its simpler than having paired wheels for steering, or 4 wheel independent, especially since we don't get 2 globes in the kit anymore, or 2 of any appropriate motor for that matter.
Unread 17-08-2005, 00:42
RogerR's Avatar
RogerR RogerR is offline
AKA: Roger Riquelme
FRC #3844 (Wildbots)
OT: center distance calculator
off topic, but...
Originally Posted by Holtzman
...(I calculated the center distances with Matt Adams sprocket center distance calculator. Thanks Matt)...
link to M.A. center distance calc.
i felt obligated to post a link to the calculator for those who missed it the first time (or weren't around). its really an invaluable tool, and has saved me some work and frustration.
<edit> FYI, it runs in excel </edit>
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 17-08-2005, 07:43
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
It looks like you have all the bases covered. I would look at the upper bearing being a little larger in diameter with a central hole for wiring big enough so as to allow power and control wiring. The lower bearing/followers are a good idea too. Remember though that using the chain and sprocket design raises the steering power demand and allows for objects to block the turning if they get caught between the outside of the wheel module and the robot frame. Tank steering is OK for changing orientation but is not need for normal driving. As always (after it is built) practice, practice, practice.
Good luck!
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-07-2009, 19:15
rums40 rums40 is offline
rums40 is an unknown quantity at this point
I am looking to purchase a 4 wheel 'crab' or strafing chassis for use on a powered chair project. Can I purchase your design or can you build one for me?
Unread 08-07-2009, 19:28
Data Nerd
FRC #0079
Holy Thread Revival!
You may be interested in http://www.chiefdelphi.com/forums/sh...ad.php?t=77623 You might not get many results when asking in this thread because it is quite old, but who knows.
pic: ThunderChicken Chassis Teaser Swan217 Robot Showcase 1 01-03-2005 19:11
pic: Not your typical chassis (team 820) JKnox Extra Discussion 12 14-02-2005 22:32
pic: 2004 chassis 930 CD47-Bot Robot Showcase 9 04-02-2004 19:48
pic: Team 190 Chassis and Driveline CD47-Bot Robot Showcase 1 01-02-2004 01:57
